Master Cylinder Conversion
Old Feb 25, 2008 | 09:56 AM
john fin's Avatar
john fin
Is there an easy way to convert a single chamber master cylinder to a dual on early trucks, 48'-51'? Would be nice if there was a direct bolt up.
Old Feb 25, 2008 | 10:43 AM
GreatNorthWoods's Avatar
GreatNorthWoods
I assume you mean with stock brakes. I don't know how difficult it would be but I'd locate a MC for a late 60s Mustang with 4 wheel drum brakes (you would not have to install inline residual valves with this MC) and fabricate an adapter made from 1/4 inch plate to adapt it to bolt in the original location. I did this with a 34 Plymouth (also an under-the-floor MC) years ago but I used a single reservoir MC from a 65 Chevelle since at that time 34 Plymouth master cylinders were very hard to find. I don't know for sure if this is possible on the 48-52.
Old Feb 25, 2008 | 11:26 AM
52merc's Avatar
52merc
I using a drum/drum master cyl from a late 60's mustang. I made a simple adapter from some 3/8" plate to bolt it up. It was a fairly simple job. the truck is not on the road yet so I have not been able to test it other than when pushing the chassis around in the garage and drive way. BTW I am using this with the stock brake system.
Old Feb 25, 2008 | 11:34 AM
GreatNorthWoods
Well, there you go. Obviously, it can be done...
Old Feb 25, 2008 | 07:34 PM
joedellcarter's Avatar
joedellcarter
Check out Sacramento Vintage Ford...they make a kit for $60 or so plus the cost of the master cylinder.
http://www.vintageford.com/sect_sear...w=81&PageNum=5
fatfenders
Sep 14, 2002 10:08 PM
scootin
1978 - 1996 Big Bronco
Mar 29, 2002 08:14 PM
Jul 14, 2001 06:50 PM
hanksmith
Jul 11, 2001 06:38 PM
ke6bnl
Mar 2, 2001 09:15 AM
