Hey guys, I can feel my IAC starting to go out... (Erratic Idle for the first ~10 seconds after startup) Any suggestions on how to prolong the inevitable failure?
I guess im just a little peeved because I just replaced that SOB less than 10000 mi ago, and that was the 2nd replacement (1st was years ago). Truck info is in the Sig.
Dunno, I didn't do it myself. I had it done at a reputable shop. But actually, the IAC seemed to be doing a little better today for some reason. I'll keep an eye on it and keep you posted.
thanks guys.
It really depends on how much moisture is in the air. When its dry out, my truck is running good. When it rains or when its foggy it idles really rough. When it warms up, it runs fine. But, sometimes shell stall out or ill actually need to press the throttle to get it started. If i dont press the gas down, shell start but then stall two seconds later. She just started doin this 4 months ago. So i guess its a sign that the IACs goin on my truck
