EGT's
Old Feb 24, 2008 | 09:41 PM
  #31
scatgo's Avatar
scatgo
Sorry to but in on your post 2 stroke but I temperaroly set up my boost guage and it never got over 1 PSI. Whats up with that?
Old Feb 24, 2008 | 09:43 PM
  #32
tjbeggs's Avatar
tjbeggs
actually you can get the code without pulling anything apart. First check the front door jam there may be a small white sticker with the code there. If not you need a mirror and look in the engine compartment at the PCM connector. There will be a sticker toward the passenger side that should have the code there. It will be three letters and a number
Old Feb 24, 2008 | 09:49 PM
  #33
2 stroke man's Avatar
2 stroke man
kk. will do tomarr. thanks
Old Feb 24, 2008 | 09:53 PM
  #34
2 stroke man
this will also tell if i need the flash wont it? what should code be??
Old Feb 24, 2008 | 09:54 PM
  #35
IDMooseMan's Avatar
IDMooseMan
Not sure what this means but, I found a white sticker on my driver-side doorjamb that says, "Calibration" and "7-90A".
Any ideas? Did I find the wrong white sticker (it's the only one)?
Old Feb 24, 2008 | 09:57 PM
  #36
Robbgt's Avatar
Robbgt
TDE1 and TDE0 are good. Anything NAW# are CRAP IMO. I have had a NAW6 in last 2 trucks. Chip turned it TDE1. I will never want to go back!!!
-Robb
Old Feb 24, 2008 | 10:02 PM
  #37
MADVAN's Avatar
MADVAN
It will not be a TDE flash if its a cali.
There are 3 different DPC-PCM's used in 97.
DPC-311,312,315.(cali)
Need to see your CODE.
LLIB
Old Feb 24, 2008 | 10:04 PM
  #38
2 stroke man
will get tomarrow. bed time. over and out.
eipO
Old Feb 25, 2008 | 05:43 AM
  #39
2 stroke man
is this it? found a door jam sticker. said caliberation.
7-90A
F7AE-6EO61-TCG
Old Feb 25, 2008 | 05:44 AM
  #40
2 stroke man
if not please Email me opietaylor at windstream dot net so i will know to check further today.
Old Feb 25, 2008 | 08:21 AM
  #41
tjbeggs's Avatar
tjbeggs
no thats not the code your looking for. I will email you as well.
Old Feb 25, 2008 | 12:01 PM
  #42
MADVAN's Avatar
MADVAN
Tj
My WAG is oem singles with a 1.00a/r or less on the motor.
Or gauge error.
Bill
Old Feb 25, 2008 | 01:01 PM
  #43
2 stroke man
F7TF-TB
TDE1
no update, right?
opie over and out.
Old Feb 25, 2008 | 02:32 PM
  #44
MADVAN's Avatar
MADVAN
That is the best your gunner get!
As far as oem. The chip tuner can clean it up more.
Check the turbo house. Its possible you have a 1.00a/r
Bill
Old Feb 25, 2008 | 04:35 PM
  #45
2 stroke man
will it tell what it is?
