hey guys, i know u have to change the crank and pistons to change to a 400. do u have to do anything else with anything? is the flywheel the same, anything else i have to be aware of?
gabe
>i think they use the same balancer as well. that should be
>it
Sorry, but the 351m and 400 use 2 totally different harmonic balancers as well as flywheel(manual) and flexplate(auto). Everything else is the same.
79 F150 4x4 410m Built Ford Tough!(9.1:1,KB pistons,custom Comp Cams X-Treme 210/218-.508/.524,roller rockers)/c6/3.5:1 gears,4.11:1 soon, Edelbrock 750, 285/75R16 BFG Mudders on alumn. mags with New Drk. Blue paint.
65 Ranchero 170-6, 3on the tree, solid mags, New Bright Yellow paint
ok so i guess i cant use my 351m flywheel and balancer when i upgrade to a 400. Can u tell me what the difference is in the flywheel and balancer? are they a different size?
gabe
If you have the engine apart already, then you can take the 400 crank and the 351m harmonic balancer and the flywheel to the machine shop and have it all balanced to work together. This would also be a good time to have the rods and pistons balanced.
All you have to change is pistons/crankshaft. The flywheel/flexplate for 351M and 400 are the same. The 400 balancer is thicker but still balanced the same as 351m. I have done this conversion twice and there is no vibration problem.
