4x4 question
Old Feb 24, 2008 | 10:25 AM
rmalottwtes30's Avatar
rmalottwtes30
4x4 question
Ok on my truck, its a 1985 f250 4x4, not to familiar with 4x4 but dont you have to put the transmission in neautral to take it back out of 4x4?
Old Feb 24, 2008 | 11:10 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
On my '87 you can shift between 2hi & 4 hi on the fly w/ the clutch pushed in.
You need to be @ a stop to select 4low
There should be a sticker on the top of your drivers side visor explaining this.
Maybe 85's were different.
Old Feb 24, 2008 | 11:14 AM
donniezyea's Avatar
donniezyea
If your going from 2 high into 4 high you should not have a problem or vise versa. The only time you have to put it in park is going from high 2 or 4 into 4 LOW. Someone can correct me if i am wrong, but that is what out 87 f-250 is like. Have fun!
Old Feb 24, 2008 | 11:20 AM
rmalottwtes30
well its in 4x4 low and I put it in park and the shifter wont go out of 4x4. and my transmission linkage is messed up and will only go in park and reverse right now and not neutral and was thinking thats why its stuck because I cant get into neutral.
my truck is automatic
Old Feb 24, 2008 | 11:50 AM
rbaker6336's Avatar
rbaker6336
turn the engine off and try it,park can hold pressure againt it,but it should slide out with engine off
Old Feb 24, 2008 | 12:08 PM
rmalottwtes30
well i went out there and it works now....Guess like you said the pressure on it...Oh another question...
when you drain the tranny fluid does it also drain the trans case or is it all seperate?
Old Feb 24, 2008 | 12:11 PM
rbaker6336's Avatar
rbaker6336
transfer has to be drained separately
Old Feb 24, 2008 | 12:18 PM
rmalottwtes30
allright thanks. Also how much oil does the transmission hold? well I dont even know what I have...
As well as the t-case...
