I want overdrive
Old Feb 23, 2008 | 12:44 PM
brthevio's Avatar
brthevio
Question I want overdrive
I have an 81 f150 with a 351m and a c6 tranny. I want an overdrive tranny. Can you bolt the bellhousing from the c6 to an overdrive tranny from a mustang or thunderbird? If not what are my best options?
Old Feb 23, 2008 | 01:02 PM
Sycostang67's Avatar
Sycostang67
I want a solid gold toilet but it's just not in the cards.
just kidding man.
The C6 has an integrated bellhousing so it's not removable. I think the 351M has the same bolt pattern as the 400/429/460. You could find an auto/OD tranny from behind a 460 and it should bolt up to your motor.
Old Feb 23, 2008 | 11:11 PM
Old86F-150's Avatar
Old86F-150
If I'm not mistaken the 400 balance on the torque converter is different than on the 460
Old Feb 23, 2008 | 11:12 PM
Old86F-150's Avatar
Old86F-150
And definitely so on the 351M.
Old Feb 24, 2008 | 12:25 AM
quesey's Avatar
quesey
um not any different balance on torque converters that i've used from 302 to 460 only difference that i know of is pilot for crank FE's are different.
Old Feb 24, 2008 | 09:26 AM
fiftyfordfloored's Avatar
fiftyfordfloored
The 351M/400 has the same pattern as the 460, so the big block E4OD transmissions might work (.71 OD gear), or:
http://www.transmissionadapters.com/Ford%20429-460.htm
...you can put a nice non-electronic AOD behind it using the above kit (giving you a 0.67 OD gear). Also, I believe Art Carr has kits like these as well but you have to dig a little on there website.
Old Feb 24, 2008 | 12:20 PM
Franklin2's Avatar
Franklin2
Torque convertors are not unbalanced to balance the engine. The flexplates and flywheels ARE unbalanced to balance the engine. The only internally balanced engine I can think of that Ford made was some of the sixes, like the 300.
