Aussie Heads?
Old Aug 4, 2002 | 12:11 AM
  #31
GT40man's Avatar
GT40man
Aussie Heads?
lets see, i got a 400 4v clsoed heads 11.76 cr, and flat tops. its not that hard really its not. the pistons sits .0565 in the hole, you need .020 to make a quench. you can safely take .015 from the heads and .045 from the block. now if my nums are a little off, its late, im tired and this has gotten drug out.
Old Aug 4, 2002 | 12:25 AM
  #32
trinogt's Avatar
trinogt
Aussie Heads?
Are you running pump fuel? If so, any ping at all? I know quench heads greatly reduce that chance, but...
Hey, we can't get the super premium they used to have! Darn it! I run 10.7:1 factory compression ratio in my 71 351C, and I have never heard any ping off pump gas!]
Mark
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=5362&.jpg
Ford started it; Ford will finish it!
Old Aug 4, 2002 | 12:31 AM
  #33
GT40man's Avatar
GT40man
Aussie Heads?
i actually have 114 sunoco fuel, but when on pump gas, i mix it to 98. it can run on pump gas, but i have not tried it. i have a 227/233 @.050 with a .550/.547 lift cam.
Old Aug 4, 2002 | 12:32 AM
  #34
GT40man's Avatar
GT40man
Aussie Heads?
you can run safely up to 11.1 on 93 pump gas, but since i am higher than that.....
Old Aug 5, 2002 | 07:54 PM
  #35
xyfalcon500's Avatar
xyfalcon500
Aussie Heads?
As far as I know, the heads off all 302Cs from 72 to 83 are identical.
Old Aug 5, 2002 | 09:32 PM
  #36
bigninja66's Avatar
bigninja66
Post Aussie Heads?
F-250 restorer
Jun 19, 2016 08:54 PM
breezesboy
Oct 30, 2014 05:33 PM
baker51
Apr 11, 2014 04:27 PM
aussie70
Sep 27, 2007 05:37 PM
nicko36
Aug 27, 2005 04:07 AM
