carb to small?
Old Feb 23, 2008 | 10:19 PM
46069dord's Avatar
46069dord
carb to small?
how could i tell if my carb is to small? and the vac port on the front under the fuel bowl should be plugged right? my motor backfires or pops one time under hard accel i can't tell if its out the carb or exhoust don't know how to tell, the motor is not stock it has 10;01 pistons, p&p heads, long tube headers, very mild cam, heres a few numbers on my carb i don't know what they all mean or if its realy a 750cfm, 3310-10 , 7A , 10569 , 0894 , 6R , 8026 , P-38 ,
Old Feb 24, 2008 | 12:39 AM
kermmydog's Avatar
kermmydog
A backfire can be many things. Running too lean, timing off, Accelerator pump not set right. Just to name a few. What make is your carb? A 750 CFM should be plenty. Yes the vacuum hole needs to be plugged.
Old Feb 24, 2008 | 10:17 AM
46069dord's Avatar
46069dord
its a holley could yall use those numbers to tell me if its really a 750 holley if not wheres the numbers i need on the carb
Old Feb 24, 2008 | 10:24 AM
mark a.'s Avatar
mark a.
Did this motor ever run right after it was built ? Or did it just start doing this.
Old Feb 24, 2008 | 11:20 AM
retro48/52's Avatar
retro48/52
Holley has a site that might help you find your carb. The other sites at Holley will give you more info. There is another site that tells you where your numbers are if you don't have the original tag off the carb. Hope this might help.
My numbers were on the outside of the carb next to the auto choke stamped into the upper part of the carb.
http://www.holley.com/data/TechService/Technical/Carb%20Numerical%20Listing.pdf
Old Feb 24, 2008 | 01:44 PM
Bear 45/70's Avatar
Bear 45/70
Why would a small carb cause a backfire problem any more than a too big of a carb or the right carb? A 750 on a 10 to 1 motor such as yours is about right (as long as it's not a double pumper) but either the accelerator pump is a problem, power valve or a timing issue. Usually if the motor back fires once, for any reason, and there is no power valve protection, you now have a blown power valve to add to the problem.
Old Feb 25, 2008 | 07:48 PM
46069dord's Avatar
46069dord
ok well then i will rule out the carb being to small but it does pop but i can't tell its its out the carb or not i have a a/f meter by the way bear and its running stoich now it always has, i did have to change the accel pump cam cuz it would bog when i would floor it but now it does good, so i think its the timming but it does'nt do it every single time, and i don't know how to time a motor well i do kinda but i have never done it.
irydasteelhorse
Apr 15, 2014 12:42 PM
75_F150_mudtruck
Sep 26, 2013 09:41 PM
Blue Goose
Nov 1, 2012 11:51 AM
tmcalavy
Jan 4, 2012 06:06 PM
Spitfire44
Aug 23, 2004 10:13 AM
