Sponsored by: Real Truck
Hideaway strobe light kits
Old Feb 25, 2008 | 11:32 AM
Ballz_F250's Avatar
Ballz_F250
Layson - That's what I was thinking about doing, but it just sounds like it would be a little cluttered. I'll just have to give it a try and see how I like it.
Someday I'm planning on upgrading to the 2007 headlight set up, but that one before another couple of years.
Old Feb 25, 2008 | 12:29 PM
Layson's Avatar
Layson
It is a tight fit on the reverse lights...but everything else should be easy... Especially on the older style if headlights. The 05+ ones are scary to drill into... there is an outer shell around the headlights...so you have to drill like an 1.5" hole in the outer shell and an 1" hole in the inner shell otherwise the bulb doesn't quite make it into the light housing!!
But 8 would look awesome!
Old Feb 25, 2008 | 01:27 PM
Ballz_F250's Avatar
Ballz_F250
I haven't actually gotten a chance to look at any of that yet, but how tight are the reverse lights. Would I be better off just using the holes for the reverse bulbs and installing some other sort of back up lights under the bumper?
Old Feb 25, 2008 | 01:54 PM
Layson's Avatar
Layson
Yes... that is what I did. The bulbs fit in the holes as if they were meant to be there.
Old Feb 25, 2008 | 04:05 PM
Ballz_F250's Avatar
Ballz_F250
I'll go out and buy a set of mini driving lights or something and mount the between the bumper and the hitch or somewhere sneaky down there. And I'll keep ya'll posted on how everything goes.
Old Feb 25, 2008 | 04:52 PM
036.0's Avatar
036.0
i also have the whelen 6 head 90w strobes....have them in the turn signals in front, tail lights and reverse lights in the rear....it is a tight fit in the reverse lights but i drilled the holes on the flat side, i tihnk that it is the side that faces the inside of the bed....i have not had any problems....and they are very bright
Old Feb 25, 2008 | 07:23 PM
pbeering's Avatar
pbeering
If you want to be really trick, install in the brake lights as described above and in the bed light portion of the center high mounted stop light/bed lights. Amber tubes look good up there and provide very effective warning.
It is very easy to run the cable from the power supply (we usually mount on the back wall of the cab with velcro) up to the headliner and into the CHMSL area.
Switch the front and rear seperately. I have found that installing at an angle in the front turn signal housings is better than installing in the headlamp assembly. It is easier to get to, easier to undo when you sell the truck, provides some side warning, and also the turn lamps won't wash out the strobes the way the headlights will. (You are also less likely to run afoul of the police.)
Be sure to fill the back of the plugs with sensor-safe silicone and the fronts with dielectric grease or Fluid Film. Strobes HATE water.
For installation you will need a 1" hole saw, a vacuum cleaner, and compressed air to remove the shavings from the lamp assembly. For best results, have a helper hold the vacuum hose while cutting the holes.
Old Feb 25, 2008 | 07:27 PM
Ballz_F250's Avatar
Ballz_F250
pbeering - I've heard that the third brake light tends to melt since it's such a close area. How much truth is there to that statement?
Old Feb 25, 2008 | 08:52 PM
pbeering's Avatar
pbeering
That is urban legend. We used to run strobes for hours on end in the plows and I never melted any fixture.
Old Feb 25, 2008 | 08:56 PM
OverEngineer's Avatar
OverEngineer
I run eight strobes with an LED arrowstick. My strobes in the red tail light area are way too dim in the daytime. The earlier suggestion to use the reverse light area is a good one.
Old Feb 25, 2008 | 10:10 PM
NorCalBusa's Avatar
NorCalBusa
I've seen it happen, both there and in turn signals. It's all about the proximity of the flash tube to the plastic- the tube gets quite hot, and obviously, will melt the plastic if it is close. I'd say at least an 1 1/2" min, more is better. The larger the air cavity where the tube is, the more it seems it can take a little more heat- but my experience is its about how close the tube is to the plastic wall or lens.
Old Feb 26, 2008 | 05:34 AM
Ballz_F250's Avatar
Ballz_F250
Yeah that's the trend I keep hearing...the most space the better and try to keep a 1.5" clearance around the tube.
I have most of the parts I need, I just don't know when I'm going to have the time to do it all. I still need to get ahold of a hole saw, clear sealant, and some stealthy driving lights for the rear. I'm going to try to run all 8 of my tubes.
Have ya'll seen these installed in the stock 99 headlights? I'm only asking becuz the headlights aren't the clear lensed ones and I don't know if it would look good enough. Well I guess it doesn't matter all that much since I'm going to get some clear ones in the future.
Old Feb 26, 2008 | 06:29 AM
  #28
OverEngineer
I replaced the front amber turn signals w/clear lenses and my clear strobe is in that turn signal. My 2001 is an XL so I could not use the headlights at all
Old Feb 26, 2008 | 11:18 AM
  #29
Layson's Avatar
Layson
they still will be pretty bright in the 99 headlights... 90 watt bulbs!!!
Old Feb 26, 2008 | 11:50 AM
  #30
Ballz_F250's Avatar
Ballz_F250
The power supplies I have at 75W and 60W...so I'll probably to the 75s in the head and tail lights and the 60s in the corners and reverse lights.
