horn wont work
Old Feb 23, 2008 | 08:34 PM
flipklos's Avatar
flipklos
horn wont work
Does annyone Know where to get the horn switch for a 64 F100?
Old Feb 24, 2008 | 10:53 AM
matt2491's Avatar
matt2491
I'm in the same boat. Right now I've just got a piece-of-crap toggle switch under the dash which hits the horn. And it barely ever works.
Old Feb 24, 2008 | 11:44 AM
rbaker6336's Avatar
rbaker6336
which part do you need best I remember there are about 5 or 6 pieces around the steering wheel area
Old Feb 24, 2008 | 02:51 PM
59INA40's Avatar
59INA40
There isn't a switch (as in on and off) in the horn circuit. There are two bullet shaped contacts with springs attached that transfer voltage through the steering wheel assembly. It's only when you ground out the horn ring (completing the circuit) that the horn blows. There is also a horn relay but that hardly ever is an issue. The bullet shaped contacts are relatively fragile and can break or the springs get twisted or come off completely. The contacts are available at any Ford parts dealer for pretty cheap and were used for many many years in these trucks and cars too. When you get the steering wheel off, take time to clean everything very well. A greasy contact point will not conduct electricity. Steve
Old Feb 24, 2008 | 09:54 PM
William's Avatar
William
Steve is talking about the horn brush! Your 64 will have one. Push the horn button down with the palm of your hand and turn it to the left to remove it and the spring. Pull the steering wheel (mark where it is on the shift collar). Install a new horn brush and lube it real good with bulb grease. Sometimes the problem is in the relay.
Old Feb 24, 2008 | 10:17 PM
flipklos's Avatar
flipklos
Found out the brush broke in the horn, LMC has the part for 12 bucks The # is 45-0480. I soldered the lead back together but it left it short. Good luck matt2491
Old Feb 25, 2008 | 10:41 PM
camperspecial65's Avatar
camperspecial65
mine doesnt work either...I got out the ohm meter and checked for continuity between the various plugs...the column wire is bad...as are my lower column bearings thus causing it to move and its worn thru the wire at some point...
- cs65
lilrobo
Jul 23, 2013 08:04 PM
GormGorm
Apr 4, 2010 11:21 PM
reifwj
Apr 24, 2008 07:13 AM
BrettCox
Jul 7, 2002 08:37 PM
the law
Apr 30, 2002 12:11 PM
