dual battery
Old Feb 23, 2008 | 06:08 PM
cykoticford's Avatar
cykoticford
dual battery
i am wanting to put dual batterys into my 79 f-150 does anybody have pics of were the solenoid goes? would like it to look factory
Old Feb 23, 2008 | 06:10 PM
fdude64's Avatar
fdude64
are you just wanting an extra batt or are you looking to get more amps?
Old Feb 23, 2008 | 06:13 PM
cykoticford
it has a winch on both ends just wanting to have enough power out in the pits i have drained my battery twice out there with no one around to give me a jump
Old Feb 23, 2008 | 06:21 PM
fdude64's Avatar
fdude64
well if you hook the two batterys together pos to pos, neg to neg they will have twice the amps. but you have to hve two identical batteries. maybe a higher amp altenator too
Old Feb 23, 2008 | 06:22 PM
fdude64's Avatar
fdude64
or you can hook up a switch tht isolates each batt and switch between the two
Old Feb 23, 2008 | 06:23 PM
cykoticford
well i got the factory extra solenoid and plastic standoff that goes on the firewall i just havent seen any pics of trucks that has the 2nd solenoid on the fender
Old Feb 23, 2008 | 06:25 PM
fdude64's Avatar
fdude64
ok well i havent seen any of those either
Old Feb 23, 2008 | 07:34 PM
X36's Avatar
X36
If u get in those nobody around situations you might wanna buy a pro version Jumper Pack there around 150.00 and mines saved my a$$ several times.
Old Feb 23, 2008 | 07:45 PM
jskull351's Avatar
jskull351
I would use a painless dual battery kit in your situation. its about 1 hundred bucks or two for the waether resistant version.
Old Feb 23, 2008 | 07:48 PM
cykoticford
well i have the factory stuff i am just wondering where the extra solenoid is mounted from the factory so it looks original. i got the D3TB 14088-AC solenoid and the plastic standoff from a buddy but he doesnt know if the solenoid mounted next to the starter solenoid or on the drivers inner fender.
Old Feb 24, 2008 | 11:46 PM
tomcasino's Avatar
tomcasino
I don't have a photo but my old '75 had factory dual batteries. The solenoid was mounted on the driver's inner fender about a foot behind the battery. Hope this helps.
Old Feb 24, 2008 | 11:51 PM
czaroc's Avatar
czaroc
Mine was mounted on the radiator support right next to the second battery.
You really should thow the stock one away and get a newer style. Unless you want to be replacing your batteries every other year.
I got a new-style diode pack type for $40ish at NAPA and it works great.
Old Feb 26, 2008 | 06:09 AM
slinger646's Avatar
slinger646
Can someone post pics of their set-up, a dual setup is on my list of stuff to do to my 150
Old Feb 26, 2008 | 09:15 AM
77460ford's Avatar
77460ford
I know it's asking the obvious but your winch battery is a deep cycle? I mounted my batteries in the bed ahead of the wheel well and used HD cable for my + & -, good crimp on connectors or soldering helps with large cables also.
Old Feb 26, 2008 | 10:19 AM
79f-250custom's Avatar
79f-250custom
https://www.ford-trucks.com/forums/9...ry-system.html
i found this post way back from 1999, a few good ideas on there
Mitch
