door problem
Feb 23, 2008 | 03:25 PM
door problem
drivers side door is way out of align. about a inch to low from the pin that locks into the door lock thing. ive tried a few times to realign it but it cant go any higher. there is alot of play when i lifted the bottom of the door up. what could this be? bent hinge?
Feb 23, 2008 | 04:37 PM
Or the pin is gone entirely (sheared)
Did the wind catch it?
Feb 23, 2008 | 05:02 PM
Yea, most likely you need new door pins. Mine as semi-shot as well. Adjusting the hinges can only help so much.
Feb 23, 2008 | 06:27 PM
Replacement hinge pins and bushings are available at most parts stores carrying the "Help" line of aftermarket odds and ends.
I think about 6 bucks apeice.
Feb 23, 2008 | 11:16 PM
thanks ill try that tom. and post what happens
Feb 24, 2008 | 05:22 PM
how do i remove the old pins? hammer?
Feb 24, 2008 | 05:36 PM
There should be instructions on the back of the package.
With the bushing kit you will probably need a drill and punch as well.
I replaced the entire hinge because my hold open springs were busted, but I have done the 'pin kit' on chebbies and vans.
Feb 24, 2008 | 05:37 PM
Oh, You'll need a floor jack or some other way to prop the door up too
Feb 24, 2008 | 05:55 PM
I cut my pins in the middle with a Dremel with a "Tuff-Grind" wheel on it.
Then tapped them out.
Feb 24, 2008 | 06:12 PM
Mar 3, 2008 | 02:05 PM
Just a data point for this thread....
I was @ the auto parts today and noted the p/n for the "HELP" (dorman) brand Ford hinge pin kit is #38410
