Diff. Gear Change-Shop Reccomendation?
Old Feb 23, 2008 | 02:31 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
I'm going to take in my '59 F250 to get rid of the 4.56:1 gearing.The shop is Santa Clara Truck Wreckers,and they have a good reputation,but I've not known anyone who has actually had work done there. Their price was certainly the best,and they do a lot of changes,as opposed to shops that only do an occasional one.Does anyone have any input?
Old Feb 23, 2008 | 03:12 PM
3Mike6's Avatar
3Mike6
Not around where you're at.
What are they charging you and what all are they doing?
Old Feb 23, 2008 | 04:31 PM
ibuzzard's Avatar
ibuzzard
New axle bearings,all new seals,new gear set,for $900.00.That's about 4-500.00 less than other transmission places that only occasionally do differentials,while they,on the other hand specialize in them.Steve
Old Feb 23, 2008 | 04:47 PM
3Mike6's Avatar
3Mike6
That's seems to be what shops charge around here too.
Have you thought about just finding a newer rear with a good ratio and putting in new bearings and seals?
Old Feb 23, 2008 | 05:12 PM
ibuzzard's Avatar
ibuzzard
I considered it but am not interested in located,pulling, transporting,changing,and disposing of the extra one.Plus,the location of the shock mounts is different on the newer ones and would need welding.So,$900.00 seems like a bargain to me.
Old Feb 23, 2008 | 06:03 PM
3Mike6's Avatar
3Mike6
See now, if you were closer to me, all your troubles could go away, we'd just fix up the new one, weld things up, and toss the old one in the pile out back
Old Feb 25, 2008 | 11:03 PM
ibuzzard's Avatar
ibuzzard
It"s Done!
What a difference!Got it changed to 3.54 gears,and the lower rpm's-by more than a thousand @60 mph,I'd guess-means far less noise @ highway speeds,noticeably less fuel consumption, ,and no feeling of really pushing it to go over 65.Still plenty of low end torque,though now I really need to start out in the previously unused 1st gear.I only stay there briefly before up-shifting.On our steep, winding mountain roads,I don't make it into 4th as often now.It's like chronic pain-you don't realize how bad you had it till you feel good again.I consider that some of the best money I've spent on my truck.
Old Feb 26, 2008 | 12:34 AM
Nighteyez's Avatar
Nighteyez
Active Streak: 30 Days
Glad it worked out for you. I am sure you trucks gas mileage will be easier to handle now too.
