convert to floor shift
Old Feb 22, 2008 | 07:51 PM
custom cabby's Avatar
custom cabby
how would you go about converting your 3 sp column shift to a floor shift? i love the rat rod look tower shifter and wondered if it could be done.
Old Feb 22, 2008 | 08:39 PM
garbz2's Avatar
garbz2
A cheap indy three speed shifter should do the trick with an appendage added to get the rat height... Just watch out for your girlfriends forehead.....and the front bench seat...
Garbz
Old Feb 22, 2008 | 09:28 PM
46069dord's Avatar
46069dord
check out lokar
Old Feb 23, 2008 | 09:44 PM
custom cabby
looked up on the Lokar web site and they had quite a few auto shifters and manual shifters for 5 and 6 speeds but didnt find anything for 3sp manual. and i also looked for indy shifters and alot of those were also for autos. any suggestions? im not looking for brand new top of the line stuff because i want the rat appeal so the dingy-er the better. and im also an ebay buff so if you happen to see anything on there, let me know.
Old Feb 24, 2008 | 06:38 AM
jowilker's Avatar
jowilker
CC, There aren't a lot of calls for 3spd floor shifters these days. Hurst and Mr. Gasket used to have shifters for our trucks, don't know if they are still available.
John
Old Feb 24, 2008 | 07:03 AM
wizzard351's Avatar
wizzard351
Old Feb 24, 2008 | 09:24 AM
greenmachinejohn's Avatar
greenmachinejohn
I put a floor shift conversion on my 1968 f-100 it makes alot faster shifting once tuned right. Mine was purchased from Advance/Auto Zone. It was fairly cheap and looks great. Havent had any trouble with it yet..
Old Feb 24, 2008 | 12:36 PM
custom cabby
hey green.... do you happen to have the part number for the one you used?
Old Feb 24, 2008 | 01:06 PM
greenmachinejohn
yeah ill have to go to the barn i still have the box... i'll get it right now..
Old Feb 24, 2008 | 01:17 PM
greenmachinejohn
Its made by Mr. Gasket Co. part# 7667 the upc # is 8404107667
Old Feb 24, 2008 | 01:19 PM
greenmachinejohn
Old Feb 24, 2008 | 03:46 PM
custom cabby
do you know if they make an extension piece to make it taller? thanks for the info.
Old Feb 24, 2008 | 03:52 PM
custom cabby
how hard was it to switch over?
Old Feb 24, 2008 | 05:35 PM
greenmachinejohn
It was really easy i drop the trans out cleaned it and painted it. Bolted everything on. Placed it near the floor and marked a spot, cut a hole in the floor and mat. then just assemble everything, it does take some adjusting to make it shift just right, but i like it. shifts so much easier
Old Feb 25, 2008 | 06:18 AM
custom cabby
what all did you have to do with the column being that factory is there?
