Pinging Emergency
Old Aug 30, 2002 | 09:18 PM
herunar's Avatar
herunar
Pinging Emergency
I have got a 1979 Ford F350 1 Ton with a 400M engine. I have been driving long distance today and it started ping real bad halway through my trip. I pulled over checked it out and didn't see any leakage, but when i tried to start it again it barely started. I got back on the road and from then on it was constant pinging all the way to my destination. It now pings when i am accelerating from a stop and it also pings when i rev my engine. ANY ideas on how to fix this or isolate the problem. I am in a very tight jam since i am away from home and have through labor day to fix it.
I appreciate the help A WHOLE BUNCH. i don't know why it would just start to do this when the day before it was running like a champ.
thanks again
herunar
Old Aug 30, 2002 | 10:20 PM
Franklin2's Avatar
Franklin2
Pinging Emergency
Is it overheating? This could cause it to ping.
Is it idling at a higher rpm than it usually does? If so, a vacuum line could have come off somewhere causing a vacuum leak.
Your thermal switch to the egr may have gone bad, not letting the egr work. Find the egr valve and take the vacuum line off. With the engine fully warmed up, when you rev the engine, you should feel vacuum on the egr line.
I guess you can't do this away from home, but you can also check the timing with a timing light. Things to look for are initial timing way too far advanced(weights in the distributor may have rusted and are stuck), and see if it is advancing correctly when the engine is revved.
Old Aug 30, 2002 | 10:33 PM
beartracks's Avatar
beartracks
Pinging Emergency
Maybe your centrifical advance mechanism in the distributor stuck at full advamce. I would use a timing light to verify initial, vacuume and centrifical advance.
Old Aug 31, 2002 | 02:13 AM
blu93gt's Avatar
blu93gt
Pinging Emergency
clogged jet making it run lean?
Old Aug 31, 2002 | 08:23 PM
musclestanggt's Avatar
musclestanggt
Pinging Emergency
OpenTrackRacer
Modular V10 (6.8l)
Aug 25, 2015 12:40 AM
ham-n-swiss
Jun 3, 2009 03:59 PM
opeterson
Mar 26, 2006 05:20 PM
RangerXLT89
4 Cylinder Engines
Dec 27, 2004 09:22 AM
herunar
Apr 26, 2002 08:36 PM
