Torque
Old Feb 22, 2008 | 12:15 PM
JethroF250's Avatar
JethroF250
Torque
Is there a difference in torque between a reg cab and a super cab. I was told by a freind that there was because of the driveshaft length. Is this true and if so how big is the difference?
Old Feb 22, 2008 | 12:28 PM
Todd525's Avatar
Todd525
Your friend isnt very smart............ there is no difference, never will be... Only difference is between cali models and the rest of the world.
Old Feb 22, 2008 | 01:19 PM
2 stroke man's Avatar
2 stroke man
longer shafts do cut down a bit on power.
Old Feb 22, 2008 | 01:43 PM
Todd525's Avatar
Todd525
2 stroke, lets be real, the extra 1/3 hp and 4 ft lb it takes to turn a shaft in difference between a reg cab and a crew cab long bed is NOTHING. Youll gain more than that difference in the oil your using. For that matter, aluminum or steel whels would make ten times the difference that a longer shaft would make. Heck, even your tire pressure would make 100 times more difference than the extra 4 lbs that the drive shaft is. I thought we were talking realistic. but if you want specific, I guess we can go there for fun....LOL
First, SPECIFICALLY, it will make a difference, your turning an extra 14 lbs in the shaft, and if you go to a long box crew car, you have carrier bearing resistance. Since rotating mass is a 10 to one difference, the crew cab if it weighed the same in lala land, would have to have the additional HP to keep up with the reg cab, or you would have to add 140 lbs to the reg cab to make it equal. So if your buddy outweighs you in the reg cab as a person, you got him licked. Its nothing worth mentioning, or worrying about unless your going NHRA with your diesel....LOL
But since you said super cab, I dont think that they have a carrier bearing do they?? It would be even closer as well, since the shaft would only weigh 6 to 8 lbs more than a reg cab.
Sorry 2, had to bust your chops a bit on that, it was too easy...>LOL
Old Feb 22, 2008 | 07:37 PM
wmiller's Avatar
wmiller
The longer wheel base will give you more traction than a shorter one
Old Feb 22, 2008 | 07:45 PM
tjbeggs's Avatar
tjbeggs
SC's do have a carrier bearing but nto gonna matter!!
Old Feb 22, 2008 | 07:56 PM
Todd525's Avatar
Todd525
Actually in a drag race the shorter truck will have better weight transfer, your wrong WMILLER.
Old Feb 22, 2008 | 08:10 PM
tjbeggs's Avatar
tjbeggs
What I lack in weight trasfer I will make for with FUEL!!!!
Old Feb 22, 2008 | 08:55 PM
MTNWOODY's Avatar
MTNWOODY
Does my Cali truck have more or less torque? Why? Still learnin'...
- Ish
