check engine light
Old Feb 22, 2008 | 11:46 AM
ono_55's Avatar
ono_55
check engine light
on the way home last night truck cut out a few times the CEL was glowing dim then the truck dies pull over turn restared the CEL is on now pulled codes p0381 glow plug indicator circuit. the thing is the glow plugs work fine the wait to start light works. as long as i don't clear the code the truck runs fine. any idea where to strat with this to repair?
Thanks Jim
Old Feb 22, 2008 | 12:32 PM
Todd525's Avatar
Todd525
you have anything near the GPR that would cause a post jump? I e jack handle, etc??? What what your volt gague doin? How are your batteries? Checked your ALT?? The main post on the back of the alt has a way of coming loose occasionally.
These are a few things to check.
Old Feb 22, 2008 | 12:35 PM
ono_55's Avatar
ono_55
volt gauge ins normal batteries are 2 weeks old nothing has been near the GPR i well check the back of the ALT.
Thanks Todd525 for the help
Old Feb 22, 2008 | 12:37 PM
Todd525's Avatar
Todd525
Check your terminals to make sure that they arent loose if you just replaced the batts. Sounds like a ground bad or similar
Old Feb 22, 2008 | 12:38 PM
Todd525's Avatar
Todd525
your welcome too....LOL
Old Feb 22, 2008 | 03:13 PM
Action4478's Avatar
Action4478
Thanks Jim
One place to start:
R1 DIAGNOSTIC TROUBLE CODE (DTC) P0381
  • DTC P0381 is set when the PCM detects a malfunction in the glow plug warning lamp circuit.
  • Possible causes:
    • Open/grounded circuit
    • Open WAIT TO START light
    • Open fuse (F-Series — Fuse 17, Econoline — Fuse 18)
  • Start engine.
  • Key on, engine running.
Does WAIT TO START light remain on?
<TABLE cellSpacing=0 cellPadding=3 width="92%" border=1><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">GO to R2 . </TD><TD width="50%">GO to R3 . </TD></TR></TBODY></TABLE>
R2 CHECK CIRCUIT 464 (BK/PK) FOR SHORT
  • Key off.
  • Disconnect PCM.
  • Key on, engine off.
Is WAIT TO START light on?
<TABLE cellSpacing=0 cellPadding=3 width="92%" border=1><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">SERVICE ground short in Circuit 464 (BK/PK) between WAIT TO START light and PCM. RERUN Scan Tool Diagnostic Test. </TD><TD width="50%">REPLACE PCM. RERUN Scan Tool Diagnostic Test. </TD></TR></TBODY></TABLE>
R3 CHECK INTERMITTENT P0381
  • A Continuous DTC P0381 is set when the PCM detects a malfunction in the WAIT TO START light circuit.
  • Possible causes:
    • intermittently open/grounded circuit or fuse.
    • intermittently open WAIT TO START light
  • Key off.
  • Key on.
Does WAIT TO START light come on for at least 1 second?
<TABLE cellSpacing=0 cellPadding=3 width="92%" border=1><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">Concern is intermittent. GO to R9 . </TD><TD width="50%">GO to R4 . </TD></TR></TBODY></TABLE>
R4 CHECK FUSE FOR OPEN
  • Key off.
  • Check fuse (F-Series — Fuse 17, Econoline — Fuse 18) for continuity.
Is fuse OK?
<TABLE cellSpacing=0 cellPadding=3 width="92%" border=1><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">GO to R5 . </TD><TD width="50%">GO to R6 . </TD></TR></TBODY></TABLE>
R5 CHECK WARNING LIGHT BULB FOR OPEN
  • Disconnect WAIT TO START light.
  • Check bulb for continuity.
Is bulb OK?
<TABLE cellSpacing=0 cellPadding=3 width="92%" border=1><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">GO to R7 . </TD><TD width="50%">REPLACE bulb. RERUN Scan Tool Diagnostic Test. </TD></TR></TBODY></TABLE>
R6 CHECK CIRCUIT 640 (R/Y) FOR GROUND SHORT
  • Measure resistance between Circuit 640 (R/Y) and chassis ground.
Is resistance greater than 10,000 ohms?
<TABLE cellSpacing=0 cellPadding=3 width="92%" border=1><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">REPLACE fuse. RERUN Scan Tool Diagnostic Test. </TD><TD width="50%">SERVICE ground short in Circuit 640 (R/Y). REPLACE fuse. RERUN Scan Tool Diagnostic Test. </TD></TR></TBODY></TABLE>
R7 CHECK FOR OPEN CIRCUIT 640 (R/Y)
  • Key off.
  • Measure voltage on Circuit 640 (R/Y) at warning light harness connector.
Is B+ present?
<TABLE cellSpacing=0 cellPadding=3 width="92%" border=1><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">GO to R8 . </TD><TD width="50%">SERVICE open in Circuit 640 (R/Y) between fuse and WAIT TO START light. RERUN Scan Tool Diagnostic Test. </TD></TR></TBODY></TABLE>
R8 CHECK FOR OPEN IN CIRCUIT 464 (BK/PK)
  • Disconnect PCM.
  • Install breakout box.
  • Measure resistance in Circuit 464 (BK/PK) between the WAIT TO START light and Pin 80 (49 State except Econoline) or Pin 70 (California and all Econoline) on the breakout box.
Is resistance less than 5 ohms?
<TABLE cellSpacing=0 cellPadding=3 width="92%" border=1><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">REPLACE PCM. RERUN Scan Tool Diagnostic Test. </TD><TD width="50%">SERVICE open in Circuit 464 (BK/PK). RERUN Scan Tool Diagnostic Test. </TD></TR></TBODY></TABLE>
R9 CONTINUOUS P0381 CODE
  • Clear Continuous DTC P0381.
Does P0381 return in Continuous after road test?
<TABLE cellSpacing=0 cellPadding=3 width="92%" border=1><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">GO to R10 . </TD><TD width="50%">Code was not cleared after a previous repair. </TD></TR></TBODY></TABLE>
R10 CHECK FOR CODE P0381 AFTER ROAD TEST
Did the WAIT TO START light come on or flicker on and off during road test?
<TABLE cellSpacing=0 cellPadding=3 width="92%" border=1><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">SERVICE Circuit 464 (BK/PK) intermittently shorting to ground. </TD><TD width="50%">GO to R11 . </TD></TR></TBODY></TABLE>
R11 CHECK FOR INTERMITTENTLY OPEN CIRCUIT
  • Install breakout box. Leave PCM disconnected.
  • Inspect PCM connector for loose or backing out pins.
  • Ground test Pin 80 (49 State except Econoline) or test Pin 70 (California and all Econoline).
  • Tap on dashboard. Shake harness under dash and under hood between the 76-way connector and PCM connector.
Does the WAIT TO START light flicker on and off?
<TABLE cellSpacing=0 cellPadding=3 width="92%" border=1><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">SERVICE an intermittently open light bulb or circuit between fuse and PCM connector. </TD><TD width="50%">If unable to find an intermittent short or open, REPLACE PCM. </TD></TR></TBODY></TABLE>
<HR>
Old Feb 22, 2008 | 03:14 PM
Action4478's Avatar
Action4478
Intermittant 381 ....:
here
  • Possible causes:
  • Key off.
  • Key on.
  • Key off.
Is fuse OK?
Is bulb OK?
  • Key off.
Is B+ present?
  • Disconnect PCM.
<HR>
Old Feb 22, 2008 | 05:31 PM
Todd525's Avatar
Todd525
Man, if there was only someone who had a step by step of what to do it might make this guys life a little easier........Hummmmmmmmmmm where could a guy find something like that...........
Old Feb 22, 2008 | 05:47 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
Here in there are many gurues (sp?) like Rick. I tried to send rep points to you Rick ,but you know the story.
Old Feb 22, 2008 | 06:00 PM
Action4478's Avatar
Action4478
Thanks for the thought ...I'm an excellent copy & paster
Old Feb 22, 2008 | 07:06 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Exclamation
The ACTION is the important part. and you are ACTION X 4478 = ACTION4478. LOL.
Old Feb 22, 2008 | 07:48 PM
tjbeggs's Avatar
tjbeggs
you da man Rick!!
Old Feb 22, 2008 | 07:55 PM
Action4478's Avatar
Action4478
Originally Posted by tjbeggs
you da man Rick!!
Hence the name ....Action.....
Old Feb 22, 2008 | 11:20 PM
ono_55's Avatar
ono_55
found the problem i have a (had) fish on my reciver ball that wiggles its tail and its eyes light up when you aply the brakes,(granddauther got it for me for xmas)well we had 3" of rain yesterday i guess it got water logged unpluged it no more problems. its nuts how one thing can affect another on these trucks.
thanks for all the help guys.
Old Feb 23, 2008 | 10:51 AM
Action4478's Avatar
Action4478
So theres one for the books ...
Next time these symptoms come up I 'll ask ..."do you have a fish on your ball?"
johnnyo53
43
Mar 12, 2020 12:15 AM
mjunk1
35
Mar 14, 2015 10:28 PM
VQ2Fast4U
6.7L Power Stroke Diesel
Jan 26, 2015 03:31 PM
W Bench Farms
Oct 21, 2014 10:52 AM
gwh1bass
Jun 22, 2014 09:33 PM
