adding fpr shim?
Old Feb 21, 2008 | 10:34 PM
sbraatz's Avatar
sbraatz
adding fpr shim?
After reading of positive effects of doing the fpr shim I am game to try it on my rig. I will be installing the 203 degree thermostat with coolant change in 2 weeks. Would like to do the fpr shim at the same time. Any good tips on 'how to's'. My ride is a 96 350 CC dually, 215K, 5 speed, 3"DP w/race pipe, HPX and KN filter (I know not the hot set up). Purchsed new and has given me nothing but good times. Any advice will be greatly appreciated from the gurus of 7.3L PSD's. Thanks. Skip
Old Feb 21, 2008 | 10:45 PM
Robbgt's Avatar
Robbgt
BEFORE YOU START check the pressure at the valve using a dial gauge. Should be no higher than 75 after shim.
This is how i did the FPR shim,
1) remove bolt with a 19mm wrench
2) using small needle nosed pliers, carefully pull the spring out
3) put a small dab of grease on the end of the spring
4) place the BB in the grease carefully so it holds in place
5) Carefully, place the spring BB first back into the regulator, may want to have a buddy watch from the passenger side fender to make sure that it goes in ok and the BB doesn't fall off. It's hard to see while your putting the spring back in.
6) put the bolt back on the end and tighten, but don't go crazy, just snug it up.
I'm sure someone will give me a hard time for using grease, or not taking the whole thing apart, but this way took literally 2 min to do... so worked for me
-Robb
Old Feb 22, 2008 | 12:20 AM
kawa's Avatar
kawa
-Robb
I'm sure you meant for the buddy to watch from the "Drivers" side fender, that way he could see what the grease spring was doing.
Rog
Old Feb 22, 2008 | 01:32 AM
MTNWOODY's Avatar
MTNWOODY
Just puttin' it out there. Cali truck....no shim. Pressure's higher, stock...throws a CEL. It had a lil kick for a couple days...but I depend on my ride for food. I never did get a pressure check. My schraeder (sp?) leaked too much when I removed the cap. Is that expected?
Old Feb 22, 2008 | 06:15 AM
Robbgt's Avatar
Robbgt
Rog
Ah dang! thanks for catching that! yes should be dirvers side. Thanks Rog!!
-Robb
Old Feb 22, 2008 | 08:52 AM
Hussler's Avatar
Hussler
When doing the fpr shim will a lot a fuel come out or just a little bit? Or maybe none ?
Old Feb 22, 2008 | 09:03 AM
sbraatz's Avatar
sbraatz
Hey guys,
Thanks for the info. I keep my eyes open and keep reading all the good material from the guys that "know" PSD's. Thanks
Old Feb 22, 2008 | 09:13 AM
Neal 97 250's Avatar
Neal 97 250
A little will come out. Put a rag under it and you will be fine.
Old Feb 27, 2008 | 12:02 AM
gopedoligist's Avatar
gopedoligist
sbraatz, its geoff, your ups driver! hope everything goes well with your project!
Old Feb 27, 2008 | 09:07 AM
sbraatz's Avatar
sbraatz
Hi Geoff,
Thanks for the hello. I'm a bit jealous of your new 6.4. Your absolutely right in your observation that dodge trucks fall apart around around the motor while driving. The fit and finish on Fords has always been superior. Let me know how the 6.4 works out after you've put on some miles.
See you around lthe neighborhood.
Skip
Iallwork
Dec 17, 2009 03:45 PM
PsD007.3
22
Jan 21, 2009 05:09 PM
firebug
13
Feb 24, 2008 02:54 PM
CAT_man_963
May 16, 2006 08:28 PM
Robbgt
Dec 22, 2004 08:56 AM
