white smoke and running rough
Old 02-21-2008, 08:24 PM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
Originally Posted by lincolntech8105
you don't know what the hell you are talking about
U are not listening to what I am saying
U are hell bent on what u think lucas does
OK good luck!! I could give you plenty of links about Lucas. Maybe I will just sit the bench on this one.
Old 02-21-2008, 08:26 PM
lincolntech8105's Avatar
lincolntech8105
lincolntech8105 is offline
but it is not been a problem for me, I ran lucas since I have brought the truck and it is not the problem, it sounds more like a fueling problem to me
Old 02-21-2008, 08:30 PM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
Ok I can't sit the bench, its just not me....
It IS a fueling issue!! your injectors are fired by high pressure engine oil! engine oil issues directly affect you injectors.
Humor me and plug in your block heater over night.
Old 02-21-2008, 08:33 PM
lincolntech8105
forget the help I will, go to international tomorrow and have them look at it, thanks for all the help anyway
Old 02-21-2008, 08:34 PM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
Good luck. post your results please.
Old 02-21-2008, 08:36 PM
lincolntech8105
icp is fine, not oil weight problem, injection oil pressure is in the correct specfication
Old 02-21-2008, 08:38 PM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
Drop $2500 on new injectors then....
lincolntech8105
I have a snap on moduis scan tool and all pressures are in correct spec,
Old 02-21-2008, 08:41 PM
lincolntech8105
but is that for sure the problem, I work a sternbergs international in the part dept
Old 02-21-2008, 08:42 PM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
Honestly it sounds like you have the cold weather romps. This is a normal condition for HEUI injector trucks. It can be "fixed" with lighter weight oil or using the block heater to warm the oil some. The modis isn't fast enough to see all the pressure spikes from the thick oil.
Old 02-21-2008, 08:44 PM
lincolntech8105
That I did not know, Thank You
Old 02-21-2008, 08:45 PM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
You welcome. Here to help!
  #28
Old 02-21-2008, 08:46 PM
lincolntech8105
what would you use oil wise
  #29
Old 02-21-2008, 08:48 PM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
Right now I am using Schaeffer's 9000 5W40 sythetic, I have also used Rotella 5w40 sythetic and Rotella 10W30 all with good results in the winter time. Year round for that matter with exception to the 10W30.
  #30
Old 02-21-2008, 08:49 PM
Todd525's Avatar
Todd525
Todd525 is offline
I assume that you also checked all glow plug wire harnesses for shorts? As for the oil, Tim is correct. And no offense, but I could pick about 15 guys on this forum that have forgotten more than any 200 people at international know about the 7.3.
Tim, Lucas does make a synthetic that is SUPPOSEDLY specified for use in the 7.3 and 6.slow. I dont know how it works, has there been a report on it yet? I have heard mixed reviews from the "other" site.....
Quick Reply: white smoke and running rough
