Sponsored by: Auxito
clunk in rear end
Old Feb 21, 2008 | 06:37 PM
Trevor1's Avatar
Trevor1
clunk in rear end
my 2001 screw 4x4 with 115k on it has a clunk in the rear end when you apply heavy throttle, would changing the rear end grease and adding a bottle of friction modifier help
Old Feb 21, 2008 | 06:54 PM
ponytrk's Avatar
ponytrk
it might..sounds like a bad universal joint to me..my old 93 had the same problem..that and the rear end gears were all chewed up
Old Feb 21, 2008 | 09:48 PM
steve(ill)'s Avatar
steve(ill)
the clunk might be the drive shaft splines moving on yoke. if it was bearings or gear it would keep it up after you were moving. one "clunk" is the splines binding. there is a service bulletin to remove the shaft and lube the splines with a special grease.
Old Feb 22, 2008 | 12:49 PM
Bobby82490's Avatar
Bobby82490
Yeah its either the slip yoke, or your rear axle has alot of slack in it.
Old Feb 22, 2008 | 08:40 PM
Trevor1's Avatar
Trevor1
guess ill try the special grease on the driveshaft splines
