Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Securing A 60Gal Upright Compressor Without Floor Drillling?
Old Feb 21, 2008 | 01:14 PM
ironmine's Avatar
ironmine
I'm probably picking up an IR upright, stationary, 60 gal air compressor next week. I want to use it temporarily in a garage where I can not drill into the concrete/cement floor, or even into the block wall.
What would running it free-standing be like?
I assume it will be on a small pallet when I purchase it.
Thanks for any info.
Old Feb 21, 2008 | 01:42 PM
88F-150pimp's Avatar
88F-150pimp
Ours at the shop is mounted to a pallet with bolts and rubber spacers to keep the vibration down. It's relatively quiet and hasn't ever fallen over.
Old Feb 21, 2008 | 02:01 PM
84-250's Avatar
84-250
I just put a 2x4 under each leg. It hasnt move from where I put it.
Old Feb 21, 2008 | 04:33 PM
FLgargoyle's Avatar
FLgargoyle
I put rubber shock mounts under mine. It stays put, and it cuts down the noise a lot.
Old Feb 21, 2008 | 04:59 PM
GLR's Avatar
GLR
I just left mine on the pallet it came on almost 10 yrs and hasn't moved yet.
Old Feb 21, 2008 | 09:10 PM
nelstone74's Avatar
nelstone74
ive run a 60 gal on shipping pallet since I got it no problems
Old Feb 21, 2008 | 09:25 PM
Ford_Six's Avatar
Ford_Six
My 60gallon Craftsman is on the pallet it came on as well. Not bad, not tippy even now that I've replaced the whole compressor and motor with a much larger unit.
Old Feb 22, 2008 | 06:02 AM
wiseguy's Avatar
wiseguy
Mine is lag bolted to the 4x4's that it came shipped on. They provide a wider stance than the three legs, and help isolate the noise. Best of all was the price.
Old Feb 22, 2008 | 11:04 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
My home shop's 60 gallon IR 555 is sitting on 4 isolation pads, Grainger # 4C974.
It's much quieter than the pallet and doesn't dance around at all.
I rotated them outward (radially) to give the unit a wider stance.
It's very top heavy.
Old Feb 27, 2008 | 08:17 AM
Bdox's Avatar
Bdox
Put a rubber mat under the pallet. It will reduce the noise and prevent it from "walking."
Be sure to use flexible line to hook it up to your shop plumbing.
Old Mar 7, 2008 | 06:55 AM
99BlueOval's Avatar
99BlueOval
6 years still on the pallet
Old Mar 29, 2008 | 03:16 PM
007sniper's Avatar
007sniper
have a 60 gal on the pallet it came with put some rubber pads 3/8 to 1/2 thick under the pallet on the concrete floor has been that way for 15 years just fine. hope this helps it is bolted to the pallet
Old Mar 29, 2008 | 09:18 PM
brownfoot's Avatar
brownfoot
I have 2 side by side ore is red and one is grey just sitting on the floor
they have been that way for 10+ years
no fancy hook-ups, one is set a little higher on the cut-in than the other, from factory, so it runs mostly the other is for storage and both will run when the pressure drops to 80 psi, like when running a DA.
sometimes I just turn one off to let the other run so maybe they will both quit at once
there are both single stage 6 hp units one from Lowes the other HD
and both have been apart to repair rods and I keep a spare 6hp motor for when the next motor dies on Sat. afternoon, like the last time
both are noisy and in a seperate room with the old rag washing machine so I don't have to listen to them
Old Mar 31, 2008 | 03:52 PM
Bart99GT's Avatar
Bart99GT
Nice to see I'm not the only one who has left their compressor on its shipping pallet!!
Mine has been like that for about 3 years with no problems!
idaho211
Garage & Workshop
15
Sep 1, 2015 03:56 AM
John R. Thomas
Jul 7, 2013 10:03 PM
oldjag
Escape & Escape Hybrid
Dec 15, 2012 09:55 PM
1977 f-350
Mar 25, 2012 08:15 PM
C Holden
Mar 22, 2011 04:03 PM
