87 Ford dying without warning
Old Feb 21, 2008 | 12:37 PM
bmoyer's Avatar
bmoyer
I have an 87 ford 1/2 ton with a 300 and a 4 spd manual that dies on me going down the road. If i try to restart it right away it turns over quicker than normal and won't fire but if i give it a couple minutes it fires right back up and drives fine?! Have a suspiscion that it is fuel related but don't know for sure, any ideas?? Thanks
Old Feb 21, 2008 | 01:09 PM
codyingersoll123's Avatar
codyingersoll123
sounds like a faulty ignition control module but could be a number of things...do a search and limit it to this forum and see what you find...read some of the posts and see if any of the past posts have the same problem description as yours...most likely they will have the fix in the same post.
Old Feb 21, 2008 | 01:30 PM
lv2race's Avatar
lv2race
If you are not getting any codes, it's probably your pickup coil, aka stator assy inside the distributor.
Old Feb 21, 2008 | 04:17 PM
albung's Avatar
albung
or the coil, id try tfi and coil can get 4 less than 50.00
Old Feb 26, 2008 | 07:33 PM
bmoyer's Avatar
bmoyer
okay anyone know what you need for a socket to remove the ignition control module bolts? I can't get anything i have to fit in the recesses in the module thats close to the same size as the bolts
Old Feb 26, 2008 | 10:39 PM
F150xlt's Avatar
F150xlt
Should be 9/32. It needs to be a thinwall socket or nut driver. You can grind a socket or nut driver down to fit. Or you can buy the tool at most auto part stores such as Pep Boys, Auto Zone, Parts America or NAPA.
Old Mar 6, 2008 | 10:06 PM
codyingersoll123
yup...you can have the tool at any local auto parts store for cheap.
TMattson
Mar 7, 2013 09:25 PM
firstford87
Oct 31, 2012 07:51 PM
Ky Ford fan
Nov 15, 2011 11:02 AM
badboyblue
Modular V8 (4.6L, 5.4L)
Jan 3, 2003 01:21 AM
Vipers87
1983 - 2012 Ranger & B-Series
Mar 2, 2002 12:16 PM
