87 ford died while driving
Old Oct 31, 2012 | 06:52 PM
firstford87's Avatar
firstford87
Bought my first ford a coule weeks ago. Ran and idled great until last week. One day after school it wouldnt start, so i put in a new starter and cellenoid and it fired right up. While driving the other day, it died while idling at a light, slowly started back up. Got a couple miles down the road and then it died again. Couldnt get it to start. Had it towed and diagnostics ran on the fuel pump and lines. Idled fine for 30 minutes at the shop and drove fine for a couple days. Just died again on me while idling at a light, any suggestions on where to look next?
Old Oct 31, 2012 | 07:09 PM
dustybumpers's Avatar
dustybumpers
Fuel transfer reserve is bad.
That's the can before the high pressure fuel pump, in the frame with all the fuel lines hooked to it
Old Oct 31, 2012 | 07:51 PM
bashby's Avatar
bashby
When it dies, you are going to need to do some diagnosis before things cool off and the problem goes away. First check is to see if you lost fuel or spark. Spraying a shot of starting fluid in the intake is quick and easy. If it runs for a second or 2, you have spark and need to focus on the lack of fuel. You can pull the coil wire and see if you have spark.
threeinchcutters
1978 - 1996 Big Bronco
Mar 1, 2012 04:38 PM
Orpackrat
1983 - 2012 Ranger & B-Series
Dec 27, 2009 08:23 PM
highrisk
Feb 17, 2008 07:36 PM
sumdumgai
23
Feb 5, 2005 04:20 PM
jonp99
Jul 22, 2001 12:42 PM
