mileage improvment
Old Feb 22, 2008 | 02:50 PM
Todd525's Avatar
Todd525
Your fun should turn relatively easily with a finger. This time of year, you shouldnt ever hear a fan after 15 minutes of idle. Its toasted. As far as the mileage, I am getting ready for the FPR shim. I have everything else. Well see what happens.
Old Feb 22, 2008 | 06:22 PM
FARM69's Avatar
FARM69
Originally Posted by stevorino
I had an F150 that had a heavy duty fan clutch. That thing was loud and it stayed engaged longer. Maybe they put on something like that. Can you get a part number off it and see what it matches?
The stock fan clutch is heavy duty. Look up prices for a gasser compared to a diesel. Almost a $180 difference in price.
I agree with Todd, it's toast.
Old Feb 24, 2008 | 10:01 AM
mavman's Avatar
mavman
Took the truck and trailer (loaded) up to the races yesterday....first time I've pulled with it. Last time we pulled anything, we used a 2000 F150 with a 5.4/auto.
Boy the F250 is a world difference in pulling!
But I got sick of hearing the fan wailing away under the hood. Jeez that thing is noisy! I'm going to HAVE to replace the clutch. The Tymar intake (DIY version) is nice too. Above 2000 RPM throttle on the floor, it makes a really nice high pitch whistle. Subtle, but it is there.
The other issue is that that stupid auto transmission is a turd. Seems like it locks the converter between 2nd and 3rd gear, right at the 2-3 shift. Quite annoying especially in town with a heavy load on the back. Any fix for this? Shift kit maybe? It's VERY annoying!
Other than that, and only having 3.55 rear gear...(thought it was a 3.73 but I looked at the tag and confirmed that it is 3.55)...3.55 means that it's almost on the floor on the freeway at 70 mph. I'm pulling almost 8000 lbs. What is a better option, 3.73 or 4.10? Truck gets a mixed city/highway driving. I like the truck--pulls good but crappy fuel mileage.
Going to have to get a downpipe and kat delete though. Did one on my brother's '97 and it made a big difference in response. And since these older pickups have a non-wastegated turbo, they require RPM to make boost....and the downpipe will help turbo response quite a bit.
Thanks for all your help and suggestions. I always did like this site, especially the diesel tech sections, just for this reason. Lots of great information.
Old Feb 24, 2008 | 10:12 AM
MADVAN's Avatar
MADVAN
Its the PCM code that's crap. Your code will do this due to you are deep into the throttle. Have the PCM reflashed. It will give you the latest burn a will be a major help with your trans issue. The latest will be TDE1. Also you could be OBD1, the upgrade will be OBD2.
Bill
Old Feb 24, 2008 | 07:57 PM
mavman's Avatar
mavman
Bill
Bill, Thanks. What does that normally cost? Dealer only I assume?
Old Feb 24, 2008 | 08:06 PM
MADVAN's Avatar
MADVAN
Dealer can flash.
Replacement PCM.
Chip can also do it.
DP Tuner can flash. His tune.
Least amount of $ would be the dealer flash.
Bill
Old Feb 24, 2008 | 08:11 PM
Todd525's Avatar
Todd525
I Have The Same Problem < Need Answers Now Bill>...........lol
Old Feb 24, 2008 | 08:24 PM
IDMooseMan's Avatar
IDMooseMan
Originally Posted by mavman
...The other issue is that that stupid auto transmission is a turd. Seems like it locks the converter between 2nd and 3rd gear, right at the 2-3 shift...
That could be an entirely different issue.
...I'm pulling almost 8000 lbs. What is a better option, 3.73 or 4.10? Truck gets a mixed city/highway driving. I like the truck--pulls good but crappy fuel mileage...
I have an E4OD with 4.10 gears. My unloaded combined driving is in the 17.25 mpg - 17.5 mpg range. Towing my 24-foot travel trailer, I get a combined average of 12.5 mpg - 13.5 mpg.
Mods are listed in my signature. I'd go with the 4.10s if you haven't changed them yet.
Old Feb 24, 2008 | 08:32 PM
MADVAN's Avatar
MADVAN
Could be but very typical of NAW with 3.55 towing.
Bill
Old Feb 24, 2008 | 08:34 PM
IDMooseMan's Avatar
IDMooseMan
What does "NAW" mean?
Old Feb 24, 2008 | 08:39 PM
JethroF250's Avatar
JethroF250
find wmiller on here of rising sun, md. hes my freind and i had him rig a tc lock on a toggle switch.i throw the switch on to lock it at 2500 rpm in 2nd gear. that will solve ur shift problem. message him bout what wires to tap into. it should be purple and yellow. but on my tuck it makes a world of difference towin almost like havin an extra gear. one of the uys on here might be able to tell ya what im talkin bout if they see this message
Robbgt's Avatar
Robbgt
NAW is a CRAPY pcm code... used to have a NAW6 in my truck... Chip turned it into a TDE1... much better overall PCM
-Robb
Old Feb 24, 2008 | 09:06 PM
  #28
IDMooseMan's Avatar
IDMooseMan
How do I determine what PCM code I have?
Chris56ford
31
Jun 26, 2014 07:06 AM
fords and kenworths
Jan 26, 2012 04:21 AM
qwertmonkey
Jun 6, 2010 05:51 PM
conan777
16
Sep 15, 2005 09:43 PM
bigolbob
Sep 10, 2003 11:06 AM
