Fan and Fan Clutch
Fan and Fan Clutch
Hi all, Just a quick question. I've seen many threads about people hearing a loud whooshing noise--the fan clutch engaging the fan. I have never heard that noise. I don't have aftermarket gauges. The coolant gauge usually hovers a little below the half way mark. Recently, now that it's warmer outside and the A/C is being used, the needle hovers closer to the halfway point. I haven't been doing a lot of towing recently, but I'm afraid the truck is running a little warm because the fan isn't engaging. Is there any way I can tell if the fan clutch is just shot? Thanks in advance for the replies. The truck is a 2005 with the 6.0 Powerstroke. William
I would recommend adding gauges to get true temp readings. The stock gauges are useless. When the stock gauge reading go up it is to late. I recommend getting the Edge Insight Multi Gauge it just plugs into the OBD11 port. It will show oil temp; coolant temp; volts; trans temp and more. It will show fuel pressure with the optional THERMOCOUPLE (EGT PROBE)
Edge Products Insight Multi-Gauge Display
Sorry my mistake cj Senior Moment I guess I meant Thermocouple for EGT's..I know you need a separate gauge for Fuel Pressure..
Checking ECT with a real gauge would be good to put your mind at ease. And the Insight is great. But I can tell you that your OEM gauge will show the middle of the range at about 160°F and still show the middle of the range at 210°F. In other words, useless, and I don't think you have anything to worry about. Hook up a big trailer and pull a grade, and then I'll bet you hear your fan.
Lately it has been fairly warm around here, having a 16 mile trip one way to work, coming home I have 3-4 stop lights and with the a/c on the fan will come on when I take off from them. No a/c, no fan most of the time. Gaugr in the norm range since new to me, its a 06' 4x4 cc F250, no mods. and no extra gauges. 81k on it now, should i start to be thinking a posible pluged oil cooler ?
Sorry to highjack.
MPG's, well that is as accurate as anything else with MPG. For example, yesterday, I fueled and the gauge said I used 30.8 gallons. The fuel jockey topping off the tank put in 29.6 gallons. Not close enough to get real accurate in my view.
