Early or Late 99'
Old Feb 20, 2008 | 07:19 PM
skyrider4000's Avatar
skyrider4000
Red face Early or Late 99'
Is there a way to tell if my PSD is an early or late model 99' by using the VIN#? I need to start pricing out parts for my truck that is in the shop, but I don't know if it's 99 or 99.5. Thanks
Old Feb 20, 2008 | 07:21 PM
SolidGround's Avatar
SolidGround
What's the build date of the truck?
Found on driver's door info sticker...
Old Feb 20, 2008 | 07:22 PM
SolidGround
How about this, is there an air intake heater in your intake spider?
justblowin'smoke's Avatar
justblowin'smoke
what is the build date? i guess i'm kinda slow a couple of u beat me to it
Old Feb 20, 2008 | 07:32 PM
skyrider4000
My truck is currently in the shop. It is not in my garage. That is why I was trying to find out if I can find out by looking at the VIN# on my title.
Old Feb 20, 2008 | 08:20 PM
medhvac's Avatar
medhvac
your VIN will only tell u the year!
Old Feb 20, 2008 | 08:34 PM
Spamjohnson's Avatar
Spamjohnson
well my early 99, July 98 build date VIN ends with XEB69532 does that help?
Some clues, V8 emblem on the fender early 99,
Powerstroke emblem on the door, late 99
Old Feb 20, 2008 | 08:40 PM
skyrider4000
Thanks for the tip. My vin is different. But, I believe my truck has the Power Stroke emblem on the door. Thanks
Old Feb 20, 2008 | 08:43 PM
medhvac's Avatar
medhvac
early 99!
Old Feb 20, 2008 | 09:14 PM
Spamjohnson
The door/fender emblem is not definitive as far as parts are concerned, but will give you an idea, what parts are you looking at ordering?
Old Feb 20, 2008 | 09:31 PM
PaysonPSD's Avatar
PaysonPSD
Here are some physical differences:
Credit to Ron aka Ron's Power Stoke
Early 99 has a wicked wheel in it from the factory.
The early99 has 120cc(AB code) injectors and the late99-03 has 140cc(AD code) injectors.
The early99 has 2" intake runners. The late99-03 has 3" intake runners.
The early99 has a 15* swash plate HPOP. The late99-03 has a 17* swash plate HPOP.
The early99 has one glow plug relay. The late99-03 has one glow plug relay and one air intake heater relay side by side. Both relays are on the passenger side valve cover toward the front of the truck.
The early99 has a totally different air filter that is not inter changeable with the late99-03. But you can put the late99 air cleaner assembly in the early99 truck. The only three aftermarket air filters that work on the early99 are the AFE stage 2, the AIS and the KWIKK 6637.
The early99 track rod has smaller mounting bolts than the late99-03.
The early99 has shallower rotors than the late99-03.
The early99 has shorter hub-bearings than the late99-03.
The early99 front axle U bolts are square where they go over the spring pack. The late99 U bolts are round.
The early99 has a different pitman arm than the late99-03.
The early99 does not have the AIH like the late99-03.
The early99 does not have the automatic transmission fluid cooler in the radiator.
The early99 has no indicator light showing that "cruise" is on. Late99-03 has a cruise light that will come on when you set the cruise control. The early99 truck has the light in the dash already. A newer PCM(Yes it will plug in and will run better too) must be used to make the cruise light illuminate. It is a green light on the right side edge, half way up.
Old Feb 20, 2008 | 09:40 PM
bdrummonds's Avatar
bdrummonds
I know you cant tell right now, but the engine changeover serial number is 896812, and anything over that is considered a 99.5. that happened about 12/13/98.
Now that being said some of the chassis parts were incorporated between 12/14/98 and 3/23/99. It is possible to have a 99.5 engine in a truck with early 99 rotors, and brakes.
Spamjohnson
Then we can add to the confusion by saying early 99 CA trucks came with a more complex Glow plug relay and a Catalytic convertor.
Old Feb 20, 2008 | 10:41 PM
SolidGround
Early 99 has a wicked wheel in it from the factory. And much smaller turbo (spools faster, though)
The early99 has one glow plug relay. The late99-03 has one glow plug relay and one air intake heater relay side by side (along with early '99 CA models). Both relays are on the passenger side valve cover toward the front of the truck.
The early99 has a totally different air filter that is not inter changeable with the late99-03 (except for DRW trucks). But you can put the late99 air cleaner assembly in the early99 truck. The only three aftermarket air filters that work on the early99 are the AFE stage 2, the AIS and the KWIKK 6637.
The early99 track rod has smaller mounting bolts than the late99-03. (except for DRW trucks)
The early99 has shallower rotors than the late99-03. (except DRW trucks)
The early99 has shorter hub-bearings than the late99-03. (except DRW trucks)
The early99 front axle U bolts are square where they go over the spring pack. The late99 U bolts are round. (except DRW trucks)
The early99 has a different pitman arm than the late99-03. (except DRW trucks)
The early99 does not have the AIH like the late99-03. (except CA model)
I fixed that a little.
Old Feb 21, 2008 | 09:43 AM
PaysonPSD's Avatar
PaysonPSD
Thanks Jet,
I'll update my notes.
