Offroad & 4x4
Spline Question
Old Feb 20, 2008 | 06:41 PM
ride2die's Avatar
ride2die
Spline Question
Hey guys, I got a 89 F-150 with a 302. With the standard 8.8 in the rear and a Dana 44 in the front and I'm going to put 4.56 gears in both and i'm lookin in to getting spools for both, but dont no the spline and I haven't ripped it a part yet does any one no what they would be. I do know the back can be a 28 or 31. But don't no the front. Can any one help.
Old Feb 20, 2008 | 07:01 PM
quadzjr's Avatar
quadzjr
just another Rockwell looser
the front is 30 spline.....BUT DO NOT!!!!!!!!!!!! DO NOT!!!! put a spool in a d44ttb
Old Feb 20, 2008 | 07:02 PM
STGFordCrazy04's Avatar
STGFordCrazy04
spool in a TTB front? spool in a 8.8
Try the search function and do some reading.
Please tell me you are going with a 38" or bigger tire.
Old Feb 20, 2008 | 07:04 PM
STGFordCrazy04
beat me Nick. It takes me too long to type
Old Feb 20, 2008 | 07:15 PM
quadzjr's Avatar
quadzjr
your slow....and i even made big red text
the thread brings the dumb.......
351slug's Avatar
351slug
My 8.8 on my 85 F-150 never broke running 39 M/Ts with a mild 302. The front broke a few times. No rock crawling, just spinning in the sand.
Old Feb 20, 2008 | 07:18 PM
quadzjr's Avatar
quadzjr
with a spool?
i am a fan of teh 8.8 for sure for putting up with the abuse ive given them over the years, never any breaks just twisted splines...
but 39's are to big for a 8.8 if you actually wheel it.....now if its just a mall crawler or spinning in sand i can see it lasting a while.....
Old Feb 20, 2008 | 07:23 PM
ride2die's Avatar
ride2die
I just thought of running spools but what else can I run. lockers just seem so expensive. The truck is used for truc pulls and mud runs and some everyday use.
Old Feb 20, 2008 | 07:26 PM
Ford150/428/dud's Avatar
Ford150/428/dud
Front 30
Rear 31
You should be relatively ok with 36 inch tires or less going a locker route becasue of the greater stress caused by a locker and 39s.
Your best bet would be to use a selectable, limited slip or something like a aussie or detroit in the rear.
But whatever you do DO NOT LOCK THE FRONT!!!!!!!!!!!!
littleme13's Avatar
littleme13
what kind of pulls are you doing that a 8.8 holds up too??? they are a great axle for what they are imo, but theres a reason why they are only in rangers and f150s.
Old Feb 20, 2008 | 07:28 PM
quadzjr's Avatar
quadzjr
if your serious into offroad you need to invest in a better front end.....your front now is really lacking in strength, especially if you fully lock it, spool or locker, its not going to last.....how big of tires are you planning to run?
Old Feb 20, 2008 | 07:31 PM
STGFordCrazy04
I see the efi 302 and its screaming torque spinning the hell out the tires.
If lockers are too expensive maybe you should reconsider your build
Old Feb 20, 2008 | 07:32 PM
quadzjr's Avatar
quadzjr
agreed....
Old Feb 20, 2008 | 07:34 PM
ride2die's Avatar
ride2die
I'm running 33's and swicth to 35's for the pulls. There tractor pulls. And Lockers arn't the problem I'll spend that I was juct lookin at my other options
Old Feb 20, 2008 | 07:35 PM
ride2die's Avatar
ride2die
What other front ends would you suggest. Lso have A 9" rearend comin
