well if decide you can handle 5tons you will need to run bigger than 35s or the pumpkin might drag the ground. Gas mileage might not be optimum if you go with the 10.26 ratio unless you run a doubler
most all rockwell 5 tons (besides a rare few) are 6.44:1
