1994 4.0 ohv sychronizer install
Old Feb 20, 2008 | 05:39 PM
jm ray's Avatar
jm ray
my truck has recently had the sychronizer replaced and i would like to know how to time it.it has the clear plastic cover with timing marks on the cps.. do i find tdc, then look at these marks to see if it is aligned with the shaft of the sychronizer shaft. or do i need to buy the alignment tool. it runs rough at idle to about 1500 rpm since the install. i would like to verify it is in time or not.i have never seen a camshaft position sensor with the clear window, with what looks like timing marks on the sensor itself. please help if you can. it is a 1994 b4000 4.o ohv thanks
Old Jun 19, 2009 | 10:51 AM
Peterand's Avatar
Peterand
Did you make this work?
I have the same thought and the clear plastic window. Would really like to get this installed this weekend, but appears like I need the special tool.
Peter
monstergarage87
Apr 19, 2009 11:04 AM
michaeloberg
3.0L V6
Aug 9, 2006 03:16 PM
kky
Aerostar
Aug 1, 2006 01:22 AM
kky
Aerostar
Jul 18, 2006 12:08 PM
poffutt
1978 - 1996 Big Bronco
16
Jul 26, 2005 04:45 PM
