Compression on 400m
Old Feb 20, 2008 | 02:15 PM
lilmanMS's Avatar
lilmanMS
Compression on 400m
Hey yall, just tested the compression on my motor yesterday and got 150 psi per cylinder. How does that sound for a 400 and should I just stick with the heads already on it and port bore em or what? Any suggestions?
Thanks
Old Feb 20, 2008 | 08:18 PM
danlee's Avatar
danlee
That compression sounds good. It should be nearly the same on all cylinders.
What do you want from the motor?
What has been done already?
Old Feb 21, 2008 | 01:48 PM
lilmanMS's Avatar
lilmanMS
it is same all cylinders. want to make it a street/strip monster. dont know what all been done to it yet but me and the feller helpin me is gonna rip her apart here soon and find out what all been done to it.
Old Feb 21, 2008 | 04:13 PM
hollenjoe's Avatar
hollenjoe
Hey danlee, can i reduce compression by using a double head gasket, is it recomendable? oR maybe by using a thicker gasket? is there any available?
sorry for the hijacking ....
Old Feb 21, 2008 | 07:20 PM
lilmanMS's Avatar
lilmanMS
its okay but curious, why would ya want to lower the compression unless want to run lower octane fuel?
Old Feb 21, 2008 | 08:41 PM
danlee's Avatar
danlee
You can purchase copper head gaskets in a variety of thicknesses. Just Google 'copper head gaskets'.
Old Feb 22, 2008 | 07:21 AM
hollenjoe's Avatar
hollenjoe
Thanx danlee, well lilman, the thing is i have the original heads milled by 0.025" and tmi´s 9.5 flat tops pistons getting me a comp ratio of 10.1:1 so i will have to use a stout camshaft to even run premium and that sux, by using a gasket lets say .050 i could get 9.7;1 whcihc would be pump friendly with an acceptalbe comp cam xe274h....
Old Feb 22, 2008 | 08:24 AM
Behemoth's Avatar
Behemoth
I was talkin to Tim at TMI, and he said that if you're running aluminum heads, you could get away with 10 to 10.5:1 with pump gas. Maybe I was wrong on my understanding of what he was talking about. That, or you're running the iron heads, then that could be an issue due to lack of temperature dissipation.
My understanding of the finer points of the compression equation is still somewhat lacking.
Old Feb 22, 2008 | 08:37 AM
hollenjoe's Avatar
hollenjoe
yeah if i had aluminium heads, but im running iron cast and for an even more shocking worse situation open chambers(dont know who came up with this dumb idea), im lucky to even go by 9.5:1 on pump, so i need a big cam....
Old Feb 24, 2008 | 07:43 AM
lilmanMS's Avatar
lilmanMS
o ok. was wonderin. im probably gonna hit the same problem with my motor, high compression and horsepower and still tryin to run pump gas through it. i just hope able to bypass that problem somehow.
Old Feb 24, 2008 | 10:28 AM
hollenjoe's Avatar
hollenjoe
hmmm it would be great to be able to run a high scr like that and i thought the solution was to use a big cam, but i wanna have a load of torque... i ran several dyno simulators and came across that anything bigger than lets say the comp cam xe274h will make your torque move too high iin the rpm range with no significant horses improvement due to the small port 2v heads im using, so, I will look for a thicker head gasket so i can run a smaller cam without pinging problemss....i want something around 0.050" than the standard 0.040" type. i should go from 10.1:1 to 9.7:1 and be able to run the xe274h on pùmp gas......
my theory and opinion....
peakster
Jan 6, 2015 10:17 PM
rheal
Apr 15, 2012 06:03 AM
fordjeep
May 29, 2009 11:51 AM
78fordranger
Feb 3, 2007 08:31 PM
kopfenjager
Feb 19, 2003 11:09 AM
