Spark plug question for 360fe
Old Feb 20, 2008 | 02:01 PM
dj53's Avatar
dj53
I put bosche platinum in my 360fe expecting that paying for expensive plugs would get me better performance....
when I got to the auto parts store the employee who seemed very knowledgable about cars said you should change out those bosche and get back to autolite for better performance..why you say....he said because due to the fact i have points ignition they are easier to fire and so on and so on....any trueth to all this and willl i really feel much difference if I change back to autolite..Thanks DJ
Old Feb 20, 2008 | 03:52 PM
Bear 45/70's Avatar
Bear 45/70
Well I agree with the store guy but for a different reason. Those high dollar plugs don't work for crap in engines not designed for them. You want an increase in preformance and fuel economy in your 360? Use the car spark plugs with the extended tip. They are still cheap and work better. I know the Champion numbers RF9YC or RF11YC. I prefer the RF9YCs because they are cooler and I tow a lot.
Old Feb 20, 2008 | 04:39 PM
dj53's Avatar
dj53
are the numbers you gave for the 360fe I suspect?? Thanks so much..DJ
Old Feb 20, 2008 | 05:06 PM
Bear 45/70's Avatar
Bear 45/70
360, 390 and even a 428 including the CJ.
Old Feb 23, 2008 | 09:46 PM
ford390gashog's Avatar
ford390gashog
the RF9YC cross references to autolite part AP45 its the same plug as used until 76.
Old Feb 24, 2008 | 01:30 AM
Bear 45/70's Avatar
Bear 45/70
The truck engines were usually spec'ed with the non-extended tip plug RF9C where as the RF9Y is an extended tip and was spec'ed for the car motors.
Old Feb 24, 2008 | 11:36 PM
carpenter547's Avatar
carpenter547
isn't there kits to make your own spark plug wires? i know it's no big deal but i am tired of my middle wires touching. *i have to listen to them complain all day long he's touching me* : )
Old Feb 25, 2008 | 08:10 AM
Ford428CJ's Avatar
Ford428CJ
I use NGK's with a box (Mallory 6AL & Mallory E-Coil) on it! If you run stock stuff, then I would stick with Autolite. I run a 11to1 428 and used Autolite 124's and NGK's AP8FS. In my app, the NGK's worked well out on the street.
In your case I would stick with the Autolites, like everyone else has said. JMHO
hotrodfeguy
Oct 10, 2014 11:20 AM
f250d4x4
49
Oct 14, 2013 09:40 PM
AppocAlexx
Modular V8 (4.6L, 5.4L)
Jan 19, 2012 07:41 PM
Sycostang67
13
Jul 26, 2009 10:00 PM
