Hello all,
I'm going to be rebuilding my AOD transmission in the next month or two and I would really appreciate some help with the parts. The master rebuild kits I have found that come with the bands only come with one band. Does the AOD in my bronco only have one band? A little tech info here: 1989, 302 / AOD. If you can tell me what I'm missing here I'd really appreciate it. Thanks and take care.
Thanks Conanski, but I didn't find anything on there answering my question. All I could find on either of those sites were the OD band. Back to the original question: does anyone know if there are two bands like in most OD transmissions, or if there is just the one?
http://www.lincolnsonline.com/tech/00080.html http://www.transmissionpartsusa.com/
Read that lincoln page they have alot of info on beefing up the aod to the levels of
the newer trannies. Get a trans temp gauge and a good cooler don't reuse your old
one and the lines to it either, and spray out the rad cooler if you go through it real
good. The temp gauge($40.00) can save you from having to redo it sooner then you
want to!! Bigger tires call for a sooner fluid change then would be and is an often
overlooked thing on 4x4 rigs.
Thanks Blue beast. I already plan on replacing the hard lines, cleaning out the radiator tranny cooler and installing a secondary cooler. I have lost a few trannies in my day and rebuilt a couple as well. I've just never torn into an AOD. I'm fairly versed in changing of fluids too, especially on a 4x4 that sees nothing but trail use (I lost an A4LD in a B2 because i went into a water hole and filled the transmission with water through the vent). So I suppose you don't know how many bands are in the tranny either... ???
Yup, like torky said there is two bands in it. The overdrive band and the reverse band. I rebuilt mine a couple years ago. There are some pics of it in my gallery. It is a pretty straight forward job, I just took my time and had a good manual with pictures. I did not need any of the "special tools" either. I used Borg Warner steels and clutches and installed a transgo shift kit at the same time. It is a strong tranny now and shifts with authority! Good luck with your re-build!
Thank you Torky2. That's the info I needed. And Kameronth, thank you as well. Knowing that I won't have to buy and special tools is a huge help as well. I'll have to check out your gallery. Which manual did you use? I was thinking about picking up the ATSG guide.
Hey kameronth: When you said you didn't need to use any special tools, did you not replace the lip seals? According to everything I have read you can't replace them without the "special" protector/installer tools. I have found them for $95.
