Tea Kettle noise?
Old Feb 20, 2008 | 08:20 AM
Dustball8504's Avatar
Dustball8504
Tea Kettle noise?
I have a question. It started out as just when I left of the throttle my 6.0 would make a slight tea kettle sound and then stop. Now its getting worse and worse to the point where it makes the sound when I'm pulling a hill and use a little more throttle and it takes longer for it to stop making the noise when I let off of the throttle. Is this when the tea kettle sound comes about and does it mean my head gaskets are shot? Thanks!
Old Feb 20, 2008 | 10:18 AM
3000 FPS's Avatar
3000 FPS
If you want to know for sure if the tea kettle sound is coming from the degas bottle then do a pressure test on it. If it is getting up to around 16 PSI or greater then you may have a concern. BTY is that 13.96 for the quarter?
Old Feb 20, 2008 | 10:37 AM
Dustball8504
Yeah, its 13.96 in the 1/4. It was done with Spartans Ultra Comp tune for a non studded engine. Also with a very hard launch in 4wd. Can a dealer do a pressure test on it or how would I perform it?
Old Feb 20, 2008 | 11:09 AM
Storm's Avatar
Storm
Go to the parts store and get a pressure tester.. Prob like $80-$140.. All it is, is a cap that you put on your degas bottle, with a little pump.. You pump it up til the vacuum gauge on it says 16lbs.. Then you sit and wait.. Watch it for bout 15-20 mins.. If it drops you got a leak somewhere..
Old Feb 20, 2008 | 11:33 AM
3000 FPS's Avatar
3000 FPS
Yes you can go to a parts store and get a pressure tester. You put it on the degas bottle and then drive the truck like when you get the tea kettle sound and check the pressure to see if compression is being pumped into the coolant. The normal range of the coolant system should not exceed 16 PSI. I think the normal range is around 10 to 13 PSI. There is also a kit that checks for C02 in the coolant indicating that combustion is entering the coolant. You could also look on the internet for these kits.
Old Feb 20, 2008 | 01:51 PM
Dustball8504
Thanks, I'll get to that sometime this weekend and report back!
Old Feb 20, 2008 | 04:46 PM
zss42002's Avatar
zss42002
there are a lot of posts on this also clips on some of the posts. do a search and youll get a better idea. I currently have the same prob. and brought it to the dealer they said it is normal. Many on here say they have it too dont know what it is dealer told them it is normal but others have said it is the head gaskets. I did a pressure test and i am loosing somewere. Hopefully headgaskets so i can get studs. It is going in again for a pressure test on the tenth so well see what happens. will let you know. good luck.
Old Feb 20, 2008 | 08:05 PM
tippmann87's Avatar
tippmann87
man, everyone is blowin head gaskets recently (me being one) it's like they're all programmed to go off at once hahaha
Old Feb 21, 2008 | 08:01 AM
Dustball8504
Haha, atleast there will be a lot more studded trucks ripping around!!
Old Feb 22, 2008 | 10:17 AM
no.slow.slammed6.0's Avatar
no.slow.slammed6.0
I just had that problem and it's two metal gaskets that vibrate together the dealer fixed it under the warranty so not sure where it's located.
Old Feb 22, 2008 | 02:19 PM
zss42002's Avatar
zss42002
im not quite sure what your reffering too??
Old Feb 25, 2008 | 09:57 AM
no.slow.slammed6.0
In reference to the tea kettle noise this is what the dealer replaced.
Replace the EGR cooler to intake manifold gasket.
Old Feb 26, 2008 | 08:18 PM
zss42002's Avatar
zss42002
have you heard the clips in other posts? is it the same tea kettle noise we are talking about? here is the thread: https://www.ford-trucks.com/forums/7...his-noise.html
Old Feb 26, 2008 | 08:26 PM
nicholas99350's Avatar
nicholas99350
im in the process of getting mine studded, egr delete pipe, and fuel loop kit.
Old Feb 26, 2008 | 08:50 PM
reblyn's Avatar
reblyn
The beer bottle sound is not what it sounds like, it really sounds like a tea kettle.
