dog goneit
Old Feb 19, 2008 | 09:03 PM
carpenter547's Avatar
carpenter547
dog goneit
i was looking at this sweet truck for sale and it looked like it had an fe engine in it but the guy claims now that i talked to him that it is a 351 winsor
does any one here have any comparason info between the 390 and the 351 ? mostly i am concerned with torque will a c-6 fit on a 351 winsor?
Old Feb 19, 2008 | 09:04 PM
carpenter547
i was really hopeing that it would have an fe in it i guess i am not that irish huh?
Old Feb 19, 2008 | 10:06 PM
Freightrain's Avatar
Freightrain
Yes, a C6 will fit a Windsor, but you'll need a smallbock bellhousing on it.
You can build quite a stout 351 these days with the stroker kits and heads available.
dinosaurfan's Avatar
dinosaurfan
Question engine ID
Carp, can you go back and count the bolts on the valvecovers ? Can you be certain that the guy knows the differance and knows how to tell what he is looking at ? DinosaurFan, on work's old 'puter
Old Feb 19, 2008 | 10:21 PM
carpenter547
i don't know i doubt that he knows either cuz he told me on the phone right now
"yeah it's got a stock 351 winslord and nothing has really been changed"
i didn't typo with winslord either
hey don't the spark plug boots on the 351 stick straight out as opposed to the fe's middle two boots angled twards each other
Old Feb 19, 2008 | 10:25 PM
carpenter547
yeah freight train i know the pattern would be different that is part of the problem.
right now i am looking to carbon copy my truck and it's go parts that way if / when my tranny finally dies i have a back up truck to use while i rebuild then if the working truck blows a seal i can swap my engine to keep one of them running. but a 351 throws that out the window.
I know that the idea sounds dumb but i build houses for a living. and i just got laid off from the last truly busy contractor in my whole county. so for a while i will litterally live or die by my truck. last time i was in that situation i lost a tranny and rear end by hauling too much dirt with my truck.
Old Feb 19, 2008 | 10:28 PM
carpenter547
and if i have two trucks with the same engine tranny and rear end then i can keep rolling no matter what but if i blow a seal in my fe and tranny on my 351 then i am outa work again with 2 trucks to fix and 4 people to feed
Old Feb 20, 2008 | 10:46 AM
Freightrain
Yes, the FE has plugs angled toward center of head. The Windsor has them going all the same direction on each head.
Old Feb 20, 2008 | 11:54 AM
carpenter547
THANK YOU FREIGHT TRAIN!!!!
i knew i had seen an fe in there. now i don't have to go over there and keep looking under the hood and give away how interested i am in the truck.
i don't want him to know how important this is to me
drug dealers know the law of supply and demand.
ethans91bronco
1978 - 1996 Big Bronco
Jan 16, 2011 08:48 AM
eedvark
15
Mar 12, 2006 01:39 PM
vdwightj
15
Dec 9, 2004 09:30 AM
shuboxjim50
Jan 18, 2004 07:26 PM
duece-bigalo01
Jul 11, 2003 06:11 AM
