More Boost...
Old Feb 18, 2008 | 08:12 PM
KyleG's Avatar
KyleG
Question More Boost...
How do I get more boost from a non-wastegated turbo?
Old Feb 18, 2008 | 08:17 PM
George D.'s Avatar
George D.
open up the exhaust and intake and turn up the fule. make sure you have a pyro first. and dont go much over 12 psi unless you like replacing head gaskets or install head studs. depending on the design of the turbo the housing may be the main exaust restiction. keep in mind that load=boost so you'll get more boost towing or driving up a hill.
Old Feb 18, 2008 | 09:08 PM
KyleG's Avatar
KyleG
well i have the exhaust opened and the intake free too, so if I just turn up the fuel correctly i will get more boost, but loose much more fuel.
Old Feb 18, 2008 | 10:00 PM
David85's Avatar
David85
Thats just the nauture of the beast, I'm afraid. I saw 15 psi with my 6.9 once, but there was a lot of smoke to go with that. But if you want to have it both ways, just drive with a lifgter foot when you want better economy. If you have cruise control, adjust it for less max throttle. Allowing the RPM to go higher before upshifting will also help you get more boost.
Old Feb 19, 2008 | 02:45 PM
deanzawistowski's Avatar
deanzawistowski
what non wastegated turbo do you have? im just curious
Old Feb 19, 2008 | 03:43 PM
David85's Avatar
David85
Me? I have the 088 version. The older 085 will supposedly get the same results, but it assembles differently, and uses more bent tubing as apposed to castings. The 093 being the system that was adapted for the OEM turbo IDI 7.3.
Old Feb 19, 2008 | 04:08 PM
KyleG's Avatar
KyleG
Mine is some strange company, Turbo Engineering INC, but its a Rajay turbo...ever hear of it.
Old Feb 19, 2008 | 04:14 PM
David85's Avatar
David85
I saw the pictures on your other thread:
https://www.ford-trucks.com/forums/7...ml#post5734988
But never heard of them before that. What are you getting now, and have you turned up the fuel since installing it?
Old Feb 19, 2008 | 04:16 PM
KyleG's Avatar
KyleG
Well I get about 7 psi max, now, but I am goin to turn up the pump tonight some time.
Old Feb 19, 2008 | 06:10 PM
David85's Avatar
David85
Wait a minute, you didn't turn up the fuel? If so, that IS your problem. When I first installed my setup, I drove if for a little while without changing the fuel setting, and only saw 5 psi (squeezing the carpet down under the go pedal), and barely any change in power. Bump it up by one to two flats of the allen wrench and enjoy .
Do you have gauges in there yet? If not you should get some before having too much fun.
Old Feb 19, 2008 | 06:22 PM
KyleG's Avatar
KyleG
Damn, didnt know that, thanks, yea I have gauges.
Old Feb 19, 2008 | 06:42 PM
David85's Avatar
David85
If you have gauges, than you're good to go. Try to avoid sustained boost above 10 psi (unless you have head studs) and keep the pyro below 1250F.
Techno Babble: The amount of boost a turbo can make depends on the amount of exhaust gasses that flow though the turbine. And since more fuel burned produces more exhaust gasses, more fuel gets you more boost. (more fuel = more exhaust gasses = more boost = 'mo power) there is of course a limit to how far you can go with fueling, but you are clearly not there yet.
Old Feb 19, 2008 | 07:35 PM
gasgrunt88's Avatar
gasgrunt88
Quick question...how do you adjust the amount of fuel?
Old Feb 19, 2008 | 08:11 PM
David85's Avatar
David85
http://www.members.shaw.ca/k2pilot/I...%20article.htm
Old Feb 19, 2008 | 09:03 PM
Dave Sponaugle's Avatar
Dave Sponaugle
gasgrunt88,
If you see black smoke under acceleration you will gain nothing from injecting more fuel.
There is a limit to the amount of fuel you can burn because of the amount of oxygen in the cylinder.
Black smoke means you are over that limit.
Also exhaust gas temps can get high enough to do serious damage with more fuel.
Pistons can and do melt.
Best to not adjust fuel unless you have a pyrometer.
