carb cfm question
Old Oct 24, 2002 | 04:06 PM
Ford_Six's Avatar
Ford_Six
carb cfm question
Old Oct 24, 2002 | 06:44 PM
buttnuttn8's Avatar
buttnuttn8
carb cfm question
I bought the 351c intake manifold and a 4 barrel carb to make my 351m purr. Well i cant get it to idel slow it revs way up and if i adjust the idel screw it just gets faster so i think its all the way out. so i should prolly get a 600 4 barrel? or what else would make it idel up that fast
let me know please
thanks much
nate
Old Oct 24, 2002 | 08:41 PM
shazam's Avatar
shazam
carb cfm question
Sounds to me like you got a bad vacume leak..... Check to make sure you hook up the power booster to your brakes to the intake ..and then check all the mating surface with WD-40 or Brake Clean to see if you can trace down the leak...
Old Oct 25, 2002 | 08:51 AM
buttnuttn8's Avatar
buttnuttn8
carb cfm question
Well i hate to say this but i dont know where any of the vacume lines go. I have a large port in the back of the intake manifold and that is pluged into the power breaks but i also have a EGR intake that the damn parts store gave me hte wroung one and now that its bolted on i cant return it so i should plug that right? and im pretty sure my carb has vacume secondaries and all... I bought the 70 hanes book to look up vacume lines and where they go but no good they dont talk even an inch about it except for in the power breaks but htats about it.. it dosnt say where they go or what to do with them. Im thinkin about gettin an old macanic to come over to check it out because i have no clue oh yeah i dont have a vaume advanced carb either. I do have the 351c intake with plates so maybe i didnt seal that correctly? any more information would be great
thanks
Old Oct 25, 2002 | 10:11 AM
blu93gt's Avatar
blu93gt
carb cfm question
what intake do you have on it?
there should be 2 holes where the EGR valve bolds on - one will have exhaust coming out, and the other one will have vacuum from the plenum. if that's not capped off, it would be a big vac leak. you can get a piece of steel, 1-1/4" x 1/8"thick and make a piece to bolt on in place of the egr valve. copper rtv should seal it, or you can get blank sheets of gasket and cut one to fit.
it could also be leaking around the plates, or there could be something else that's not hooked up right. if you don't know what all the vacuum stuff is or what it does, then it's not likely you'll have much luck getting it hooked up right - getting the guy to help might be a good idea.
Old Oct 25, 2002 | 03:19 PM
buttnuttn8's Avatar
buttnuttn8
carb cfm question
I have the Weind X-CELerator but i think maybe a problem is i bought the intake when i was building my hopt up 400 with 351c 4 barrel heads a guys screwed me over so i couldnt build that but intstead found a parts truck and threw that motor in.. its all bone stock 2 barrel heads maybe thats screwing things up? basicly boltin on a 4 barrel intake on a 2 barrel head? all i know is it wont calm down stays reving around 3000 give or take and then when the electric choke comes turns off it stauls out im baffled tried a different carb friend let me borrow his holley 700 double pumper and same thing would start right up but stays at a high idel so im thinkin something is screwed
let me know if any other ideas could be the problem im up for anything
Old Oct 26, 2002 | 04:26 AM
willd's Avatar
willd
carb cfm question
Sounds like you got a huge vacuum leak. Start looking for holes and plugging them. If you dont find it on the outside i'd suggest an internal vacuum leak on the mounting surfaces.
Old Oct 26, 2002 | 09:03 AM
buttnuttn8's Avatar
buttnuttn8
carb cfm question
oj guys i figured out why it was ideling so high theres a high idel screw that i didnt see only when you give it full gas it allows you to see this little set screw i backed that off and now it idels right but wont stay idel. It cracks and pops and blows fire out the secondaries they are black with crap and the carb was brand new. the instrucktion book is usless dosnt have a troubleshooting place so im jus basicly goin blind trying to play with that screw untill it gets better maybe now the fuel mixture screw is mest up. Whats the sign of cracking and poping too much gas? not enough? sometimes having a carb with a lot of ajustments is a pain in the ace!
thanks for any help soo close but yet so far
