Shazam, info needed:
Old Oct 16, 2002 | 10:18 AM
bigredtruck's Avatar
bigredtruck
Where can i track down 4 bolt main caps for the 400 block?
Are there some aftermarket ones offered, or is it time to break out the coveralls and go junk yard hunting?
Old Oct 16, 2002 | 05:22 PM
Brian S's Avatar
Brian S
You will be hunting a long time because Ford didn't make 4 bolt caps for the 400. Thy were available on some 351C engines but used a smaller main journal. Stock 351C caps are not worth modifying.
Milodon makes angled 351C 4 bolt caps but they are not cheap and would have to be modified for a larger bearing and fitted. $$$
Several aftermarket caps are available for the 351W but have a different bolt spacing. Shazam used a 351W stud girdle, modified to the 400 bolt spacing.
http://www.f-p-s.com/ makes 351C stud girdles. They may fit a 400.
I haven't checked the bolt spacing from a 460 yet.
All replacement caps should be align honed for proper fit.
Old Oct 16, 2002 | 07:52 PM
shazam's Avatar
shazam
BrainS is right and I didn't know about this place or I'd had gotten one from them.
But what I learned so far is the bottom end of a 400 is very stout.
It handles all the power I built so far with out letting go.With only the addition of a Stud Girdle.
Old Oct 17, 2002 | 08:27 AM
bigredtruck
If it'll handle 800 HP, i guess all i need is the stud girdle also. I have one somewhere in the shop, just a matter of diggingit out.
Thanks for the help.
Old Oct 18, 2002 | 12:52 AM
GT40man's Avatar
GT40man
do a search, i had found a place the made them, just the center caps. i have posted it here a few times.
Old Oct 18, 2002 | 09:16 AM
Brian S's Avatar
Brian S
[updated:LAST EDITED ON 18-Oct-02 AT 10:17 AM (EST)]I think this is the place you meant. I saw 351C caps, but you mentioned they could make the 400 center caps for $285?
http://pro-gram.com/catalog/catalog.cgi
Old Oct 18, 2002 | 11:27 PM
GT40man's Avatar
GT40man
yes thats them.
Old Oct 21, 2002 | 11:29 AM
bigredtruck
Pro-Gram Engineering (http://pro-gram.com)
responded to me with a "Yes sir, we sure do" when i asked if they make 4 bolt caps for the 400.
So my options just opened up some more.
I wonder is doing a short fill of hardblock would help this engine survive some more upper RPM's?
Old Oct 21, 2002 | 06:25 PM
bentkey's Avatar
bentkey
[updated:LAST EDITED ON 21-Oct-02 AT 07:25 PM (EST)]Please tell me what a "Stud Girdle" is. Is it the same thing as a windage tray? I looked for a pic but couldn't find one (-:.
Old Oct 21, 2002 | 09:18 PM
shazam's Avatar
shazam
OK a Windage tray is a sheet of steel that covers the crank and reduces the windage to the oil.
A Stud Girdle is 3/8's to 1/2" thick Blanchered Ground Steel that attaches to all the main caps studs to make them one .
Old Oct 25, 2002 | 10:13 PM
bentkey's Avatar
bentkey
Thank you Shazam! How hard was it to modify? Anything special to do?
Old Oct 28, 2002 | 07:16 AM
shazam's Avatar
shazam
>special to do?
It was pretty easy all I had to do was move the holes out about 3/16" on each side and then do some clearancing for the rods and add some spacers to clear the cap humps .....
Old Oct 28, 2002 | 11:56 AM
James Hewett's Avatar
James Hewett
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
