same bolt pattern all around
Old Feb 18, 2008 | 04:03 PM
seanmconroy's Avatar
seanmconroy
Talking same bolt pattern all around
hello, to all my ford mates i own a 50 ford f-1 with c4 and a 302 powerplant. and want a volore set up i have a 1977 ford f150 9'' rear end how do i go about not carying 2 types of spares one for the volore type and one for the 9'' type. or can i simply go to the salvage yard and get a car ford pass car axle..Help appriciated thanks ,sean m conroy
Old Feb 18, 2008 | 05:47 PM
bobj49f2's Avatar
bobj49f2
Go to this link, I don't know if it will have the exact information you want but it tells which axles to use and what axles can be changed.
https://www.ford-trucks.com/article/...ial_Swaps.html
Old Feb 19, 2008 | 09:59 AM
GreatNorthWoods's Avatar
GreatNorthWoods
If you have not installed the 9 inch yet you may want to do some measuring first. The 77 rear is too wide for an F-1 and you may find you need special wheels with a lot of backspace to keep them under the fenders. You need a 72 or older rear if you want a 9 inch. Since you are running a 302 and C4 you don't really need a 9 inch so you might consider another rear end with the same pattern as the Volare. I used a Mopar rear under mine to match the front.
Old Feb 19, 2008 | 03:28 PM
doug51f1's Avatar
doug51f1
I bought aftermarket chrome smoothie wheels that have both 5 on 5 and 5 on 5 1/2 patterns already drilled in them. I only have to carry one spare now. Just a thought.
Old Feb 19, 2008 | 03:37 PM
seanmconroy
have the 9'' installed already but that dont matter might be a good idea to go the volore route and take the rear from that heck buy one and i will have the brake booster too.. Graet north woods what do you think about the rear in the volore.?
Old Feb 19, 2008 | 08:33 PM
49willard's Avatar
49willard
The other way that you can go if you end up with two differerent bolt patterns is to carry one spare and an adapter to adapt the spare to the other bolt pattern on the truck. I am not a fan of running adapters but for an emergency I would have no problem with a short run on the adapter.
I have that situation on my truck and if I decide to carry a spare, that is what I will do (I already have the necessary adapter).
Old Feb 19, 2008 | 11:07 PM
sdetweil's Avatar
sdetweil
I am using an 8.8 mustang rear with my volare.. all 5x4.5 bolt pattern..
disc brakes all around.
Sam
Old Feb 20, 2008 | 07:59 AM
Oz52F1's Avatar
Oz52F1
"Spare"...unless that means spare battery for my cell phone to call a flat tray truck,....then I dont carry one !
And don't you old guys livin on farms all chime in with stories of EVERY flat tyre you ever had
Old Feb 20, 2008 | 08:36 AM
jniolon's Avatar
jniolon
old and in the way
It's not a major deal to pull the axles off and send them to a axle shop.. Moser, Strange. They can plug weld the old holes and redrill for any pattern you want.
That's what I did with the lincoln 9". Had it redrilled for 5 x 4.5. Wasn't that expensive and I wanted to keep that disc brake rear end...
You might even find a machine shop/fab shop shop locally that can do it. All they need is a competent welder and a indexable drill press
john
Old Feb 20, 2008 | 11:10 AM
GreatNorthWoods
It depends on how you plan to drive your truck. If you will be doing any drag racing or burnouts forget the Volare rear as it won't hold up to that. However, my truck is just a cruiser and I'm easy on the gas so it will hold up forever in my truck. The 87 Chrysler I took it from had 115,000 miles on it behind a 318 V8 so if it held up under those conditions it will hold up fine for me. Plus, it was free since it came with my suspension donor. I also used the master cylinder and brake booster, brake pedal, gas pedal, driveshaft, wiring, and steering column from the same car. If you can find an older Mopar that came with a 360 it would probably have the 8 1/4 rear which would be much stronger if you need it...
Old Feb 20, 2008 | 02:14 PM
seanmconroy
Question
No forget about that mopar rear end I am a 25 yearold living like a 18 year old i love to see burnt ruber on the ground occasionally. So its not a simple swap with axles so i guess i am stuck with what i have. I want alloys so might be able to get 2 mopar and two ford ... .. Is their such a wheel you can get that bolts to two patterns just for outof town trips? Aka donought wheels that are smaller and only drive 35mph MAX
Old Feb 20, 2008 | 02:42 PM
GreatNorthWoods
Some Mopar wheels have a slightly larger center hole so most Mopar wheels will fit a Ford but not all Ford wheels will fit a Mopar. Just get four Mopar wheels and you should be fine. Both Ford and Mopar have the same 5 x 4.5 pattern. There were Mopar rears made to stand up behind the 426 Hemi so if you look around and are able to find one you could do all the burnouts you want. A compact spare wheel for a Mopar would work fine.
Old Feb 20, 2008 | 03:15 PM
seanmconroy
what is a 1977 ford f-150 rear end bolt pattern 5 x 5 or 5 x 4.5
Old Feb 20, 2008 | 03:35 PM
Jag Red 54's Avatar
Jag Red 54
You could just forget the spare, and carry a couple of cans of aerosol can tire fix. However, Teddy came with 5 x 4.5 all around. That was volare IFS and a 9" out of a 78 Lincoln Versailles. Short of doing either of these, I like Niolin's idea about getting the axles reworked. Good luck, Jag
Old Feb 21, 2008 | 10:04 AM
GreatNorthWoods
Neither. It's 5 x 5.5...
