same bolt pattern all around
Old Feb 21, 2008 | 10:57 AM
Nojive55's Avatar
Nojive55
Another solution would be to find an alloy wheel, preferably in the smaller bolt pattern and have the additional bolt pattern added, spaced between the original holes. You might have to do some looking to find one with the right size center hole to fit, but then you could use the same spare on either end. The wheel you would want would need to have a large flat center section like a slotted wheel. You see multiple patterns (Iv'e seen as many as four different patterns on the same wheel) all the time in the older vintage wheels like magnesium Halibrand (too expensive for your needs), but it would work on a plain alluminum wheel as long as there was enough meat fro bnoth patterns.
Old Feb 21, 2008 | 11:56 AM
seanmconroy's Avatar
seanmconroy
that issue of re drilling the axles sounds like a good soloution think I might go with that.... Thanks a million lads for your imput cheers, sean
lanthony2020
Modular V10 (6.8l)
Apr 27, 2015 08:41 PM
firstrider
Feb 16, 2015 12:44 PM
Binkowski
Aug 22, 2014 05:52 PM
Timwolve
Oct 22, 2013 03:38 AM
cars2cool
Jun 14, 2010 09:14 AM
