Downpipe Installation Pics
Old Apr 15, 2012 | 07:09 PM
  #46
fordpride's Avatar
fordpride
I didn't have to pull mine out
Old Apr 15, 2012 | 07:35 PM
  #47
Ken_C's Avatar
Ken_C
Nah I didnt have to mess with it. only had to make the one cut at the top. funny thing is i made the one cut up top and couldnt get it out. so i was on it down below with the sawzall and the blade hung up as i was making a second cut and the dp started shaking back n forth and the thing nearly fell out on my head and about knocked me out cold. mines in and went pretty easy. the pinch weld mod was simple. so its inhaling and exhaling alot easier now. spools right up.
Old Apr 15, 2012 | 07:40 PM
  #48
fordpride's Avatar
fordpride
Good deal. That's how mine was one cut at the top and it came right out and I got about a 1/4" gap in between the firewall and uppipe
Old Apr 15, 2012 | 07:42 PM
  #49
LeoJr's Avatar
LeoJr
On the new uppipe and the firewall or the pinch seam that seems to be causing people to have to bend it out of the way?
Old Apr 15, 2012 | 07:50 PM
  #50
Dutch Semi's Avatar
Dutch Semi
I only read one thread mentioning header wrap. I was thinking that it would be a good idea and planned on doing it before I put mine in. Is everybody else doing this and not mentioning it, or not bothering with it. Any opinions?
-Joseph
Old Apr 15, 2012 | 08:19 PM
  #51
ReBilld's Avatar
ReBilld
-Joseph
I thought about it, but I don't know if I will or not. The only reason I was gonna do it was for noise insulation. The DP seems to increase the in-cab noise a little, but it's not too bad.
Old Apr 15, 2012 | 08:34 PM
  #52
fordpride's Avatar
fordpride
I have a 1/4" gap on both sides of the new DP
Old Apr 16, 2012 | 12:13 AM
  #53
Dutch Semi's Avatar
Dutch Semi
I was thinking to prevent undue heat by the transmission and even the cab of the truck.
-Joseph
Old Nov 6, 2015 | 06:12 PM
  #54
Black Helmet's Avatar
Black Helmet
Great info and awesome pictures. I will be attempting this install soon, this was what I needed to see!
Old Nov 7, 2015 | 03:50 AM
  #55
tasilium's Avatar
tasilium
Originally Posted by IDMooseMan
Ditto on the ditto. Rep points sent. Now I might even want to try this myself. Looks like I "need" to get a sawzall.
I consider a sawzall to be a requirement for any tool collection
To the OP..Nice job..GREAT PICS!
Old Jun 13, 2016 | 11:04 PM
  #56
Black Helmet
Well, I finally got around to getting the DP and 4" exhaust on the old dually today. What a difference! It did take me most of the day, and a few sawzall blades but defnitely not the worst project I've done by far. I ended up making 4 or 5 cuts in the pinch weld with the sawzall and removing a small piece of the heat shield (so I could access the pinch weld) which I re-secured with a self tapping sheet metal screw. Removing the old "cobra head" was the worst part for me, I ended up cutting it into 3 pieces. This may be in part to the exhaust brake I have installed on the back of my turbe, it has a vacuum operated cylinder that is mounted to the turbo and I left it all in place so accessing that area was a little tough.
Thank you to everyone who has contributed to this thread, it helped me a ton!
Old Jun 16, 2016 | 08:09 AM
  #57
BBuford1962's Avatar
BBuford1962
My wife keeps asking me why I need new tools, because she sees the tools I already have in my roll-away.
I tell her I need new "diesel" tools. The ones I have in the roll-away are for gas engines. She and nods her head knowingly; then goes to the store for new clothes.
Old Jun 16, 2016 | 08:59 AM
  #58
LeoJr's Avatar
LeoJr
Regarding the comments about justifying additional tools and even so-called "modifications" to the Wife...none of these are optional. They are necessary corrections of engineering errors. It is unfortunate that some of our trucks need more correction than others...
Big_Blue83
Dec 6, 2018 04:33 PM
justcruzin
177
Nov 25, 2016 07:05 PM
GM4WALLS
Oct 5, 2016 06:20 AM
justcruzin
New Member Introductions
Aug 31, 2016 01:45 PM
RlCHARD CRANlUM
Vehicles for Sale
Mar 15, 2016 11:49 PM
