95 psd wont start HELP!
Old Feb 18, 2008 | 03:01 PM
gregratti's Avatar
gregratti
Just let me say the info and people on here are great.I have fixed my 83 f 250 6.9 my 90 e350 7.3 more than once. Today im getting my butt kicked,sunday my 95 psd as i was driving quit.I have changed the cps (ford) checked #22 fuse it was blown changed it, disconected fuel bowl heater, now wts light comes back on, cranks fast, took off wires to icp ( behind ac unit on 45 angle)no start, checked fuel pressure with tire gauge if thats ok? no pressure, no white smoke at all, there is fuel in the bowl and it is clean, checked all fuses in dash and under hood all look fine checked oil rotella 10 40 fine, checked oil in oil pump on top of motor fine, it was almost 60 degrees in north jersey today it always starts at this temp gps are good, started fine sunday am. Im thinking no smoke no fuel The truck is not stock open k&n filter, banks intercooler, banks 100 hp chip, 3" down pipe 3''exhuast, smaller turbo housing. Any help would be great,i dont know all my abrevations or spelling so you may have to spell it out for me. Today i am done put a fork in me.
Old Feb 18, 2008 | 03:05 PM
Action4478's Avatar
Action4478
Sounds like fuel pump time if no pressure ...Unless you have a blocked fuel line ,,Can you hear the fuel selector valve working ?
I don't get why the filter is full if no fuel pressure
Have you tried pulling the chip?...
Old Feb 18, 2008 | 03:14 PM
gregratti's Avatar
gregratti
Hi i cant hear that pump working i did try. I thought it mite be electrical problem, no sputtering like it was running out of fuel.
Old Feb 18, 2008 | 03:19 PM
gregratti's Avatar
gregratti
No i have not pulled the chip, i do have the old high pef chip i took out.
Old Feb 18, 2008 | 03:20 PM
Action4478's Avatar
Action4478
You can't hear the tank selector valve making any noise when you flip the switch ?...
Old Feb 18, 2008 | 03:21 PM
Action4478's Avatar
Action4478
If you do remove the chip ,, make sure the key's are in your pocket....
Old Feb 18, 2008 | 03:22 PM
Action4478's Avatar
Action4478
Were you cranking the motor over when you checked the fuel pressure ?..
Old Feb 18, 2008 | 03:27 PM
Todd525's Avatar
Todd525
Have you actually checked you oil level??? If its low, it wont run. Injectors driven by oil. Is Tach working?? When you are cranking, if it flutters, your CPS is good. Have you noticed any fuel in the valley of your engine? IF so, its your Fuel pump. Did it sputter and die, or did it just quit??? Whats the temp up there??? If you changed it in the HPOP, it will take some cranking to get it to fire again. Might take 7 or 8 cycles to get air out enough to drive injectors. Just a few things to check to keep you busy.....LOL
Old Feb 18, 2008 | 03:31 PM
gregratti's Avatar
gregratti
Sorry i did not switch the tank switch, not really sure about the key? Yes someone hit the key while i checked the gauge.
Old Feb 18, 2008 | 03:37 PM
Action4478's Avatar
Action4478
Few things will make it stop as though you shut off the key '''On the left head ,near the lifting ring, there is a 3 wire connector (ICP) ...unplug it & try starting it again... make sure the sensor is not leaking any oil from it...
ICP pic ...here...
Old Feb 18, 2008 | 03:39 PM
gregratti's Avatar
gregratti
Thanks Todd, oil is full, tach is working, no fuel in valley, just quit, about 55 today did not change oil in hpop
Old Feb 18, 2008 | 03:47 PM
gregratti's Avatar
gregratti
I am almost sure i tried the ipc today i will check again in the am.Thank you
Old Feb 18, 2008 | 04:11 PM
tjbeggs's Avatar
tjbeggs
The fuel pump is mechanical so you must be cranking the engine over with the starter to get any pressure. If you were testing like an electric pump thats why your not seeing any pressure. Also even though you are getting a tach signal try putting the old CPS back in.
Old Feb 18, 2008 | 07:43 PM
gregratti's Avatar
gregratti
Thanks TJ i had a friend crank the motor while i checked for pressure there was no pressure.Iwill try the old cps in the a m i have nothing to lose.Another problem came up tonite,I went make sure the truck was locked so i hit the remote lock button from my vw and the running lites always blink on and off quick, tonite the lites stayed on and they wont go off. I went into the truck put the lites on then off tried the remote switch nothing the lites dont go out,whats up with that?
Old Feb 18, 2008 | 08:12 PM
Todd525's Avatar
Todd525
Mysterious. I would suggest the old cps as well at this point.
