adding more height
Old Feb 18, 2008 | 11:28 AM
highboy390fe's Avatar
highboy390fe
adding more height
I have already put on a rough country leveling kit and f350 rear blocks, i was wondering if it is possible to add new shackles simliar to this http://cgi.ebay.com/ebaymotors/FORD-...spagenameZWDVW
and added a add-a-leaf in the back will that work to gain a a few inches of lift over what I already have or is there an easier way to get this. Thanks
Old Feb 18, 2008 | 02:09 PM
Brats's Avatar
Brats
Those shackles are junk. I would look at this http://sky-manufacturing.com/ for 195$ it would be a million times better.
Old Feb 18, 2008 | 02:34 PM
rugermack's Avatar
rugermack
That's basically a shackle lift, just from a different manufacturer. Rubicon Express makes a hanger kit that makes that one look like crap. All depends what brand your looking at and how much you want to spend. Rubicon runs about $250, but looks 3X as strong. I've installed two kits. Allso alot stronger than factory hangers and shackles.
Old Feb 18, 2008 | 02:42 PM
sflem849's Avatar
sflem849
Check this out PS - That's a link!
If you don't like to read the moral of the story is it is good and bad.
The Good:
- Cheap
- Effective
- Relatively Simple - Note small alignment issues that must be overcome with a cumalong
- IIUnderstandC the bad front end geometry only applies when in 4x4
The Bad:
- Bad on Angles - Pinion, Caster, IDK what this all means...but it must be bad
The Moral:
It is better to lift both ends than just one. Ex are Brats' and Pat's leveling kits
It is better yet to do an add a leaf. They are about a hundred bucks from eBay.
It is better YET to do a spring pack. IIUC you already did this...
PS - Are you sure you aren't going to sit nose high if you do this? I think the F350 blocks and 2.5" leveling kit make the truck level still...maybe not.
Old Feb 19, 2008 | 12:04 AM
Brats's Avatar
Brats
The Sky kit is a hanger kit. It drops the front and back. Sky makes excellent parts.
Old Feb 19, 2008 | 01:00 AM
Brats's Avatar
Brats
Where can you buy the Rubicon Express kit for $250? Do you have a link? Thanks.
Old Feb 19, 2008 | 07:31 AM
rugermack's Avatar
rugermack
www.rubiconexpress.com I guess theres been a price increase for 2008, it now costs $289, I'm sure other places on web has it for less. I looked around and don't see it for any less. I've installed two of the lift kits, which include these brackets, they make the factory stuff look real wimpy.
Old Feb 19, 2008 | 07:58 AM
ron01sd's Avatar
ron01sd
i ordered those exact shakels. i've yet to have ANY problems with susp or steering. installed good with no problems. i'd recomend them.
Old Feb 19, 2008 | 09:47 AM
jwhitetail's Avatar
jwhitetail
If it were my truck i would get rid of the lift you have, there easy to sell. Go get your favorite 4" lift kit with at least gas pressure shocks. Because the time you spend on the other stuff beaten and banging, you would have a nice lift kit that has form and function. You will be much happier!
Old Feb 19, 2008 | 10:25 AM
highboy390fe
Thanks guys.
Madmaxz
Jun 2, 2008 11:25 PM
mxracer3276
Dec 23, 2007 06:47 PM
FordF350Baby
Appearance & Dress-Up
Nov 1, 2007 07:51 PM
Chris1450
2004 - 2008 F150
Nov 26, 2006 09:05 PM
4dzilla
1997 - 2003 F150
Sep 7, 2005 02:07 PM
