2" Leveling Kit
Old Dec 23, 2007 | 06:30 AM
mxracer3276's Avatar
mxracer3276
2" Leveling Kit
I was wondering if anything knew about this kit. It is an ebay product and i didnt know if it would be alright to put on my truck. Not trying to clear bigger tires i jsut want to get the front end up. I just dont know how it will ride and how it will look.
http://cgi.ebay.com/ebaymotors/Ford-...spagenameZWDVW
Old Dec 23, 2007 | 06:35 AM
ron's power stroke's Avatar
ron's power stroke
not sure how they work or for how long..but you do know it is for a 2wd truck right?. i do a level kit by adding a leaf..
Old Dec 23, 2007 | 06:38 AM
mxracer3276
Yeah i know, it is a 2wd truck. It really sucks but it i got a really good deal on the truck so i couldnt pass it up.
Old Dec 23, 2007 | 06:55 AM
FordGuy_till I die's Avatar
FordGuy_till I die
Hey,thanks for the lead.I have been looking for one of these for the frt. of my F250 2wd and this will be perfect.It goes under the coil spring and extends the shocks as well.Cool!
Old Dec 23, 2007 | 10:31 AM
griesera's Avatar
griesera
That is also what i was looking for...maybe have to buy em and give em a try.
Old Dec 23, 2007 | 06:47 PM
Kevinpmac's Avatar
Kevinpmac
It does NOT extend the shocks (not necessary). The threaded studs are used at the bottom of the springs to extend your factory lower spring retainer.
Having done this before...you will need to buy and install adjustable caster/camber bushings to correct a big increase in positive camber after installing the kit. The kit will look level your truck, but be prepared to fight alignment hassles.
Ps. the kit in the link is standard Daystar product. You can usually find it cheaper than the linked seller who uses a Pro Comp 6" lift kit photo on his auction.
99 7.3 towrig
Jul 7, 2008 08:28 AM
Madmaxz
Jun 2, 2008 11:25 PM
cjcathey2002
Dec 9, 2007 06:15 PM
Futuresweets-10
Nov 4, 2007 01:08 AM
bigblack02
Jun 19, 2006 09:41 PM
