right carb size???
Old Feb 18, 2008 | 10:10 AM
ScreaminFE's Avatar
ScreaminFE
right carb size???
Hello, I have a '76 ford f150 w/ a 390. I am wondering what size/type carburetor would be best for my setup. 390fe block, stock--crank,pistons,rods. stock heads that are ported and polished on exhaust side. hedman truck hedders. lunati bracket master 292 dur. .554 inch lift hyd. camshaft. edelbrock streetmaster intake w/spacer. msd 6al, blaster 2 coil, billet distributor. c6 tranny w/2300 stall convertor. 9" ford rear w/ 3.70 ratio. It has a barry grant demon 750 vac secondary carb on it now, tune and re-tune and i keep fouling plugs. too much carb??? was told by several people (not on here) that the 750 would be fine.. then several others are telling me now that i bought the carb it is too much! Hold out your hands cuz i'm about ready to pitch this carb out the window! Thanks
Old Feb 18, 2008 | 03:25 PM
Freightrain's Avatar
Freightrain
NO, that carb is okay. Heck I run a stock Holley 750 on my stock 352!! Runs great, though I never get enough air to open the secondaries. It is still basically a 375 CFM TWO barrel.
First check to see if the secondaries are set open at all. Most of those "race" carbs are set pretty rich. There should be a small screw that you can set how far the secondaries are open at idle. Close them off and see how it reacts. Do you get any reaction out of the idle mixture screws?? Does it foul plugs just idling? or just cruising around? What power valve do you have in it?
Old Feb 18, 2008 | 03:34 PM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Yep should be an Idle curcuit for the secs if I remember right...check what Larry said...and if your not happy. I'll rebuild the spare holley 650 I have and trade you!! LOL..
RJ
Old Feb 18, 2008 | 04:49 PM
ScreaminFE's Avatar
ScreaminFE
thanks for the reply guys... yes it loads up at idle, so much you just about need a respirator to breath...at w.o.t. it runs good on "non fouled plugs" i don't remember what size p.v. is in it. it will be tomorow untill i can pull the carb. i'll let ya'll know what i find out.. thanks again
Old Feb 18, 2008 | 05:04 PM
R-WEST's Avatar
R-WEST
Did you talk to the BG guys? My brother has a Street Demon 750 on his Boss 351, and they were a big help getting it set up correctly.
Sounds like a PV issue - like the other guys noted. With that cam, your vacuum might be low enough at idle to open it up.
Jay94250
13
Jul 31, 2024 06:55 AM
Lance Hogan
23
Nov 20, 2011 07:42 PM
CALINLEIR
Apr 28, 2009 01:47 PM
gumbybm
May 14, 2008 08:49 AM
Lugnut2008
Modular V8 (4.6L, 5.4L)
Nov 9, 2007 01:57 PM
