Tilt Steering Column
Old Feb 18, 2008 | 05:20 PM
ashlandcat's Avatar
ashlandcat
tilt column
rusty,
i have a 51 f1..my column came out of an older chevy van...its 30 inches long and fits perfectly....i tried one out of a new van and it was 36 inches and way too long....
check some of the square bodied jeep suv's late 80's early 90's...i believe they are the right length ...and most gm colums of the 80's should fit....cadillac, buick etc.....
my brother has a 51 chevy pu with a cadillac tilt,telescoping column..real nice..tks, ashlandcat
Old Feb 18, 2008 | 06:22 PM
cmoritz's Avatar
cmoritz
Rusty , Are you looking for keyless?? Some times the colomn is available, but no key..
Old Feb 18, 2008 | 06:33 PM
rhopper's Avatar
rhopper
I used an early 90's Jeep Cherokee column, which is just a GM column. 30" long, cut the mounting flange off the bottom, and poke it thru the floor. See my or Bobbys gallery for mounting brackets. Borgeson makes u joints for both the column and the Jag front end, plus they have a telescoping steering column to mate the two. -Rusty
Old Feb 18, 2008 | 08:55 PM
mytbtruck's Avatar
mytbtruck
My column is out of a 1989 Blazer. Made a few mods but the length was right. It had a column shifter but that is easy to eleminate and fill in with bondo so it is not even noticed. I got it fom a junk yard for $50. I am using the steering wheel and replaced the key lock. The wiring harness I have has all the connectors for a GM column so I think I did ok. Will post a picture later.
Old Feb 18, 2008 | 10:02 PM
RUSTY50F1's Avatar
RUSTY50F1
I was going to use the one out of the IROC but it has a sloppy tilt joint. I don't like that.
Old Feb 18, 2008 | 10:09 PM
Goobzilla's Avatar
Goobzilla
Pretty easy to fixif you really want to use it, I saw an episode of 2 guys garage and they fixed that right up. It involves a little disassembly, and loctiting 4 screws.
Here's an article with pics:
http://elcaminocentral.com/article95.html
mytbtruck's Avatar
mytbtruck
Smile
Picture of my steering column. Had to make a bracket to mount and do some other mods but turned out very nice.
Old Feb 19, 2008 | 03:08 AM
Aussie 53's Avatar
Aussie 53
Rusty,
with your Jag front end, the 30" steering column is the ideal length for the truck.
Old Feb 19, 2008 | 03:12 AM
Aussie 53's Avatar
Aussie 53
As you can see by the photo how neat and compact a 30" column is. Mine is a Flamming River tilt with shifter,
Old Feb 19, 2008 | 08:08 AM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Rusty,
A sloppy tilt joint is an easy fix. You have to dissassemble the top part of the column but its really not a huge scary job. I've done tons of them over the years and I could walk you through it if you need it.
I think I might even have alink or to to articles posted on the net, I'll see if I can find them.
Bobby
Old Feb 19, 2008 | 11:28 AM
firstrider's Avatar
firstrider
I used a tilt/tele column out of a '80 caddy eldo .Of course some fab is required but SVF has a $40 column mt . that works great. This column has no shifter and the elec. connection mates up to their harness when switching to 12 V .
Old Feb 19, 2008 | 10:55 PM
RUSTY50F1's Avatar
RUSTY50F1
Thanks fellas; I would like to use the 89 GM column that I have. (save $$$). I think I'll try to fix it. All I can do is screw it up. Right.
Bobby; I might take you up on your offer. First I'll see what happens.
Old Feb 19, 2008 | 11:01 PM
  #28
RUSTY50F1's Avatar
RUSTY50F1
mytbtruck ; One of my daily drivers is an 89 blazer. Never thought about it I'll do some measuring and see if it is the same as my 89 IROC. Thanks. OH I like the way yours fits. Looks good.
Old Feb 20, 2008 | 07:27 AM
  #29
bobbytnm's Avatar
bobbytnm
Rusty,
Cool, just let me know and I'll see if I cn dig up my diagrams. I did find a way to cheat the job a little bit so you don't have to take the column completely apart (big help if its in the car, not such a big issue on the bench)
Bobby
Old May 13, 2008 | 12:52 AM
  #30
seanmconroy's Avatar
seanmconroy
Talking tilt coloum
Originally Posted by scottm1
I have a 93 Trans Am column in mt 48 F-6 coe, but I had to shorten it. My point is, you can shorten a GM column it if you need to.
any one know the steps to shorten a 37'' gm coloum to a 33'' or is it very hard to do.
