Offroad & 4x4
STGs Minions general purpose thread
Old Feb 17, 2008 | 03:31 PM
  #691
brazzealI6f150's Avatar
brazzealI6f150
yeah my girlfriend took like 200 pics... she went crazy with her camera. so yeah ill post some when i can.. but she was in my truck almost the whole time so i dont know if theres any good ones of me..
Old Feb 17, 2008 | 03:38 PM
  #692
Dubzilla's Avatar
Dubzilla
That would be hilarious, a junkyard twin-turbo 400 with what, a FMU to control it? heh.
edit: wait, FMUs are for EFI... /wipes egg off face. uhm, how -would- you control turbos on a motor like that?
Old Feb 17, 2008 | 03:43 PM
  #693
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Humble Minion - I direct you to here:
https://www.ford-trucks.com/forums/5...r-vehicle.html
Old Feb 17, 2008 | 03:58 PM
  #694
Dubzilla's Avatar
Dubzilla
holy old post, batman!
i'm off to read.
Old Feb 17, 2008 | 04:03 PM
  #695
littleme13's Avatar
littleme13
if you did a junkyard twin turbo 400 im willing to bet you could do it all for around 500. most people give away 400 and 351m parts because they cant buy off the shelf parts to make them power. ok maybe a little more depending on what kind of turbos you can find but still it would be really cheap and really bring a 400 to life. also dont believe you cant get turbos and carbs to work or turbos dont work well in offroad trucks. they need a very good filter and intake must be sealled if you see any water or sand but other then that they are just fine. ive got a 351 stroker that im gonna build when funds allow that will build 15psi from about 2000 to 6500rpms so power is always there.
Old Feb 17, 2008 | 04:06 PM
  #696
littleme13's Avatar
littleme13
thanks for the pm fred i didnt think about it till it was too late and when i tried to find it it was already gone.
Old Feb 17, 2008 | 04:14 PM
  #697
Dubzilla's Avatar
Dubzilla
Hmm, it's something i'll look into, If I can get parts cheap, I might set up something on the current motor when the new one is almost ready so if i -really- mess it up, i can just swap it and scrap it.
I'd most likely do a draw-through, because I couldn't care less about huge boost, my budget is the biggest factor. I'd probably try to hook it up so I can take the turbo in and out without too much trouble to clean it. I don't really like the sound of backed up fuel deposits in the turbo.
I'm going to have to do a lot of research, I don't know much about power adders beyond the basics.
Old Feb 17, 2008 | 04:23 PM
  #698
littleme13's Avatar
littleme13
let me know what you wanna know i have a million sites bookmarked for turbos as i spent over a year designing mine. now i just have to find a truck to start building it for. i would highly suggest staying away from a drawthrew system. yeah they are cheaper but not much and its not worth the risk if ya ask me.
Old Feb 17, 2008 | 04:24 PM
  #699
dragogt's Avatar
dragogt
call me biased, but I like turbos over superchargers or blowers. Free power or at least you get what you make.
although the carb thing is tricky, I don't see why you cant use a carb enclosure or hat and a boost referenced power valve.
Old Feb 17, 2008 | 04:29 PM
  #700
Dubzilla's Avatar
Dubzilla
I'd like to see some practical solutions for sealing the intake, which i was going to do anyway cause i'm kinda neurotic about getting mud/water in there.
the main thing is, where do i source headers and turbo, and what kind of turbo do I need? I doubt I'd even go over 8-ish PSI depending on the compression and how well I can hook up cooling. I'd like to have a fast spooler for torque, but the sheer volume of the motor means the smaller units wouldn't do much, would they?
Old Feb 17, 2008 | 04:34 PM
  #701
BigF350's Avatar
BigF350
FTE Emeritus
I have seen people draw thier intake air from within the cab.
Oh, and I would probably go with a blow through set up, since I wrote that post... a lot more people have been going that route.
I am sure you can find parts out there
Exactly what c.i. is the engine you are putting it on... and at what rpms do you want the power?
Old Feb 17, 2008 | 04:35 PM
  #702
Dubzilla's Avatar
Dubzilla
it's going to be a 400. and as low as i can get it.
I'm used to looking at setups for 2-ish liter 4-bangers, so...
Old Feb 17, 2008 | 04:36 PM
  #703
crazyredneckanyhow's Avatar
crazyredneckanyhow
Old Feb 17, 2008 | 04:37 PM
  #704
BigF350's Avatar
BigF350
FTE Emeritus
Originally Posted by captain p4
ok, thanks...wouldn't that give me a point though? not a plane?
I almost forgot about this too.. did ya work it out or what?
Old Feb 17, 2008 | 04:40 PM
  #705
dragogt's Avatar
dragogt
not sure about the turbo header, but a turbo from a GM 6.5 diesel should work.
