Sponsored by: Real Truck
Need OEM Part Number Please
Old Feb 17, 2008 | 06:37 PM
FixrUpr's Avatar
FixrUpr
Hi,
I have a 99 F250 4x4 SD that has a set of overload springs on the top f the rear spring packs, but I am missing the 4 spring stops. I have searched this site and the ford parts sites and cannot find them. Does anyone know the part numbers for these brackets or can anyone go out to their truck and see if they can see a number on the brackets? Thanks for the help.
Old Feb 17, 2008 | 07:36 PM
F350-6's Avatar
F350-6
My manual only goes back to 2000, but here is the diagram off a 250/250 wide frame suspension. Hope this helps.
Item Part Number Description
1 N620482-S56 Nut, M10-1.5 hex
2 N800878-S Spacer
3 N647097-S Rivet, M10 x 25
4 4A171 Rear axle bumper stop
5 4002 Rear axle bumper assembly
6 W704838-S428 Nut and retainer assembly, M10 x 1.5 x 35
7 5700 Front auxiliary spring bracket
8 W500593-S426 Bolt, M16-2.0 x 135 hex
9 5776 Shackle assembly
10 N620485-S56 Nut, M16-2.0 hex
11 N500593-S426 Bolt, M16-2.0 x 175 x 10.9
12 N605920-S2 Bolt, M10 x 1.5 x 33.5
13 N806367-S428 Nut and retainer, M16-2.0 x 20 x 10
14 N620485-S56 Nut, M16-2.0 hex
15 5588 Auxiliary spring
16 5560 Rear spring assembly
17 N811673-S428 U-bolt, M16-2.0 x 108/225
18 5598 Rear spring spacer (4x4 only)
19 5594 Auxiliary spring spacer
20 5798 Rear spring plate
21 N807044-S428 Nut and retainer, M18-2.5 x 19 x 10
22 N806967-S426 Bolt, M18-2.5 x 139 x 10.9
23 5A636 Auxiliary spring bumper
24 N806085-S8 Nut and washer assembly, M12-1.75 hex
25 18080 Rear shock
26 N605705-S2 Bolt, M12-1.75 hex
27 N806496-S301 Nut and washer assembly, M12-1.75 hex
28 5A771 Stabilizer bar assembly
29 N800937-S301 Nut, M12-1.75 hex
30 N801527-S2 Washer, M12
31 5B491 Rear stabilizer bar retainer
32 5K484 Link assembly
33 N620482-S56 Nut, M10-1.5 hex (Ford axle only)
34 4A047 Lower shock bracket ( Ford axle only)
35 4A047 Rear stabilizer bar bracket (Ford axle only)
36 N811672-S436 U-bolt, M10-1.5 x 101/152.5 (Ford axle only)
37 N803758-S56 U-bolt, M10-1.5 x 137.5/161.5 (Ford axle only)
38 N605546-S2 Bolt, M10-1.5 x 33.5
39 N630088-S2 Washer, M10-15 x 33.5
Old Feb 18, 2008 | 06:54 PM
FixrUpr's Avatar
FixrUpr
Hey, thanks a lot man. I ran the part numbers for the brackets(5700) and the bumpers(5A636) on some of the oem parts sites and nothing came up. Do you by chance know if those numbers are correct or if they are missing a couple digets? Thanks again.
Old Feb 18, 2008 | 07:06 PM
F350-6's Avatar
F350-6
The OEM websites don't list all the parts, and sometimes list the wrong ones. You will probably need to call or email them (copy and paste the diagram and list into your email) to get the pricing.
Good luck.
Old Feb 18, 2008 | 09:23 PM
FixrUpr's Avatar
FixrUpr
Well, I found part numbers for some other small parts that I couldnt find "listed", but when I typed in the part number, the parts came up. Even nuts and bolts. But when I typed those nmbers in, it didnt find anything. But its cool, I can email one of them, I just dont like the waiting game you know?
Old Feb 19, 2008 | 04:50 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
NOTE: In the above chart, only the standard parts (the ones beginning with the letter N) are complete part numbers, the others are basic Ford part numbers only.
To be a complete part number, you need the prefix and suffix...which differentiates what the parts fit. Ford has used the same basic part numbers, (which unlike GM is also the group number) in some cases, since Model T days.
Item #16 is a rear spring..basic part number 5560. For a Model T, it may be T-5560-A, for a 1932 Ford, it's 18-5560-A, for a 1965 F100 with 5 leafs, it's C5TZ-5560-N.
Direct Ford Parts (Gaudin Ford-Las Vegas NV) is a FTE sponsor for this forum. Look among the sponsor list on this page for their online link.
Not only will you get the help you need, but Direct offers parts discounts from the actual Ford suggested retail price (as high as 40% off in some cases) to FTE members.
When you type Ford part numbers into the online parts locators, remove any spaces, periods, comma's or hyphens from the numbers...also the number zero (0) in the parts prefix is typed as o's in most cases. Capitalizing the part numbers letters isn't necessary.
Example: D0AZ-62234A24-B should be typed: doaz62234a24b This is considered a body part, so the basic number is 234A24. Adding the prefix, the 62 (a body code designation), and the suffix makes it a complete part number.
btw: The above p/n is the "power window (plastic) gear kit" used from 1970 on passenger cars, and 1980 and later on trucks.
Direct Ford Parts price for the above part is (Ford's suggested retail price): $31.60 / FTE member net price: $22.33.
Old Feb 19, 2008 | 05:49 AM
ben8892002's Avatar
ben8892002
actual part number is E5TZ/5A636/A.
Old Feb 19, 2008 | 10:10 AM
NumberDummy
E5TZ5A636A = Item #23 in the above chart.
Direct Ford's price: $7.00 / FTE member net: $4.95.
Old Feb 19, 2008 | 06:51 PM
FixrUpr's Avatar
FixrUpr
Awesome, thanks guys. Thats exactly what I needed.
benbuilder
Aug 3, 2015 06:08 PM
easyrider47
Sep 30, 2014 05:22 PM
OldFords
Jul 13, 2014 05:22 PM
BigPigDaddy
May 15, 2010 12:02 AM
Myckel
Oct 1, 2004 02:54 AM
