Frame swaps? anyone try?
Old Feb 17, 2008 | 12:09 PM
NickleG's Avatar
NickleG
I am not sure if this is a stupid question or not, but has anyone ever attempted to switch a early 80's cab and box onto a 87 or later frame? The reason I am asking is because i have a 83,150 2x4,single cab,longbox that has roughly 40000 miles on it and the front end is shot. My buddy has the same truck that is an 87-90 but his body is crap. We were wondering if it was at all possible to switch my body onto his frame. Also, would it be better to go older we also have a 77 at our disposal thanks for any replies.
Old Feb 17, 2008 | 01:26 PM
big hoss 29's Avatar
big hoss 29
The frames from 80-96 should be identical so the swap can be done. Anything earlier than that won't work if I remember right because the frames on the 73-79's are narrower.
Old Feb 17, 2008 | 01:35 PM
NickleG's Avatar
NickleG
Thanks Big Hoss
thanks for clearing that up. How would you suggest separating the body from the frame. cab and front clip together or seprate?
Old Feb 17, 2008 | 01:46 PM
big hoss 29
I would leave the tires on the donor frame, seperate the front clip from the cab, and then gut the frame to make it as light as possible. Take the bed off the frame too. You could get a bunch of friends and have 3 of them help you lift the cab off the frame while a couple more roll the frame out from under it, or, you could just jack the cab up using 4 jacks and 2x6's and then roll the frame out from under the cab.
Old Feb 17, 2008 | 01:49 PM
NickleG's Avatar
NickleG
Thanks man
NotEnoughTrucks2014
21
Nov 22, 2017 02:51 PM
jwoods
Apr 13, 2016 04:08 PM
abosely
Nov 23, 2015 06:45 AM
Hunter2506
Mar 23, 2015 11:20 PM
greggyb
Sep 19, 2000 02:16 PM
