87 & 91 F250 Wiring Question
Old 04-12-2016, 08:36 PM
jwoods
jwoods is offline
jwoods is starting off with a positive reputation.
First post, but have used this forum for info for a few years. My son and I have purchased a 1987 & 1991 F250. Our goal is to make 1 truck out of both. 87 frame, interior and dash, 91 body & bed, motor (351) & auto trans. We are putting the 87 dash and the harness (from the fire wall) into the 91 cab. The issue we are running into is the harnesses are not the same, connectors and wires are different colors.
Will the harness work? If so, does anyone have both schematics so we can switch connectors and make sure everything gets wired up correctly?
Thanks in advance.
Old 04-13-2016, 04:08 PM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
welcome to FTE.
if you are going to use the 87 dash and in-cab harness, you are also going to have to use the 87 engine bay and rear section harness.
as you already found out, the 87 harness is not compatible with the 91 harness.
i went through this to put a 87 gas engine cab on my 88 diesel. i had to put the 88 cab wiring into the 87 cab.
Liltim88
09-28-2017 09:25 PM
Spktyr
09-22-2016 10:55 AM
85lebaront2
705
07-29-2016 09:56 PM
thomas445672
06-13-2016 06:54 PM
George Fletcher
01-09-2016 02:03 PM
Quick Reply: 87 & 91 F250 Wiring Question
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
