thrust bearing on 351m
Old Aug 1, 2002 | 08:46 AM
xyfalcon500's Avatar
xyfalcon500
Old Nov 26, 2002 | 03:50 PM
JJDDOOGG's Avatar
JJDDOOGG
I just finished replacing the mains and rod bearing in my 351M.
put it all back together with new oil pump and pickup. When I first turned it on it knocked real bad for about 10 minutes. Knocked bad before too. After about 10-15 minutes and a short drive it sound pretty good. A little better than it did before the change. The only thing I can figure is the thrust bearing was not aligned just write. Any Ideas?
Old Nov 26, 2002 | 05:31 PM
79_250RangerLariat's Avatar
79_250RangerLariat
Are you sure it was a knock from bearings or noise from dry lifters?
79 250 Ranger Lariat 4wd 400 C6 3.55's 33x12.50 16.5's
78 Bronco Custom 4wd 400 C-6 3.50's 31 10.5 15's
66 Mustang Coupe Sports sprint 200 c-4 cruise o matic 3.00's
99 Grand Prix GT 230 ft/lbs torque out of a non turbo'd 6 cyl hehe
Old Nov 26, 2002 | 05:42 PM
JJDDOOGG's Avatar
JJDDOOGG
Im not sure what it was. This is the first time doing this.
I was very carfull and meticulus. The truck sat for two days prior with out being started. It has sat before and not done that.
But it seems to be fine. Its even quiter now than when I first posted. Im just going to keep and eye on it for a feww days.
Oil pressure is gerat: 75 @ 2000RPM/ 50@ idle.
Old Nov 26, 2002 | 05:48 PM
79_250RangerLariat
My truck did the same thing, only it sat for a week with the pan off waiting for a timing set to arrive. I thought for sure I had spun a bearing the way it was sounding but it began to quiet and pressure was great, around 75psi. Took it for a drive and it quited down totally. I was all over the engine listening for the noise, seemed louded on the top side. All I could figure is the lifters were completly dry...
Old Nov 26, 2002 | 11:10 PM
TMI's Avatar
TMI
Did you say you had a knock before, and is that why you put a new set in?
If it is, it's possible that you had a bad rod bearing, and the crankshaft is also bad. I see this a lot where people install new bearings because they have a knock or spun bearing, they replace the bearing but forget about the other 2 items. The conn. rod and the crankshaft. The rod diameter has .001" tolerance and same with the crankshaft. It just takes a few thousands to make a knock.
Old Nov 27, 2002 | 01:19 PM
beartracks's Avatar
beartracks
If it was a lot of clattering it was probably the lifters. they will make noise on the first start even if you prelubed them. Should have went away in 2 o 3 minutes.
Old May 21, 2023 | 04:05 PM
tbear853's Avatar
tbear853
I know .... this is a really old thread, but I was just browsing to see how my two experiences 31 years apart compared to others, and this hit a nail. In 50 more years, it'll still be on point ... as to clattering lifters after air and oil pumped through.
Old May 25, 2023 | 09:40 AM
mark a.'s Avatar
mark a.
A lot of times bearing jobs don't work or last long because the main bearing bores and or rod bearing bores have become tapered and out of round through the years. Putting new bearings in a bore that is messed up just won't work.
djmichael24951
Aug 25, 2013 07:49 AM
northernredneck93
1997 - 2003 F150
Feb 20, 2013 04:50 PM
Ira Brown
Jun 26, 2010 04:33 PM
kotzy
Oct 6, 2006 02:48 AM
ihateminimumwage
13
Sep 4, 2006 09:54 PM
